Complete Novice Needs Help
Old 18th November 2011, 12:55 AM   #331
Russellc is offline Russellc  United States
Originally Posted by jimbo51 View Post
Is this any use? Looking at the properties it was created by Brian.
Yes, I do believe it is! Thanks you guys!
Russellc
Old 18th November 2011, 08:53 AM   #332
nar is offline nar
nar's Avatar
Originally Posted by richluvsound View Post
You mean on the live ? .... Sorry for being dense !
Yes, live, or mains. I believe it's the same thing with different names
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 9th May 2015, 01:49 PM   #333
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Default Finally got back to this !
Hi Gents,
finally got back this as the warm weather is here and I don't need the extra heat of the XA 160's
Got it all running of sorts . One channel running perfectly , heat ,sound !
The other channel ,no heat and distorted sound . Trying to trace the fault .
I'm hoping someone can help me trace the issue step by step ?
I have been struggling for a few hours as they are boards from ebay and probably not sanctioned copies so I've not wanted to incure the wrath I can't get on with Brian's boards ..... too small for me .
I have 30 VDC rails from the PSU .
This is the Schematic I got with the boards :
Old 9th May 2015, 05:42 PM   #334
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
piccies pls
then little flack for being cheap and blind bstrd
then we can help
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th May 2015, 06:03 PM   #335
Cheers Zen,
they weren't cheap ..... ! I know it has to be something that switches . I have replaced one ZTX ,but thought I'd get help before I got too carried away .
Here's a couple of photo's .
Old 9th May 2015, 06:07 PM   #336
Default Other end !
The other half !
Old 9th May 2015, 07:08 PM   #337
Zen Mod's Avatar
triple check values of all resistors , orientation of little bjt bstrds ( big ones even if you intend , you can't mix how to place them )
also zener etc
Old 9th May 2015, 07:09 PM   #338
Zen Mod's Avatar
gnd both inputs , no load on output
confirm what voltages you have at appropriate positions in orig schm ( you posted above)
Old 9th May 2015, 08:09 PM   #339
Ok Zen
..... I had a 47K where it should have been 4r7 ..... only 90 % out ...
I have just wired it up and hopefully that was the issue !
I'll check the voltages after supper ...
Thanks , Richard
Old 9th May 2015, 08:37 PM   #340
Got it .... I had the 47k and 4.7 k in the wrong place .... bloody eye sight ...
Thank you again , Richard
Complete Novice Needs HelpHide this!Advertise here!
Complete tube amp novice got a few questions!! Boscoe Tubes / Valves 22 22nd August 2010 05:52 PM
Could anyone help a novice? sunnycue Full Range 8 4th August 2006 06:45 AM
Novice in need of help skiermurph Solid State 2 22nd December 2004 02:52 AM
Tweakable Turntable For Complete Novice? NattyDread Analogue Source 0 10th June 2004 07:46 PM
Copyright ©1999-2017 diyAudio
