A Zen I/V variant for the Saber DAC - Page 2 - diyAudio
Old 16th October 2010, 05:06 PM   #11
jcx is online now jcx  United States
I am simulating a 2 tone balanced current input with dc bias from the PCM1794 data sheet
I like to look at IMD with 2 tone high frequency input as usually being most "stressful" distortion wise - the cs across the inputs is just a spice hack for balanced current excitation, the 2x 20KHz cs have opposite sign ac amplitudes
run the transient analysis and you should see 1:1 7KHz+20KHz output, I look at a 10mS long fft with Blackman window for good IMD product frequency resolution
Old 16th October 2010, 05:38 PM   #12
jcx,
Understood. Would this be simpler? It would also allow you to include the source imp from the DAC by adjusting the resistors. Those included here are for a 4x4 Sabre.
I will have to try this on the fully paralleled sim for the sabre.
Thanks,
Dave
Old 16th October 2010, 06:28 PM   #13
resistors would have to be in parallel with current sources, series with voltage sources
for the ESS9018 the Buffalo manual describes the analog out:
"Each analog output at 0DBFS is equivalent to a voltage of approximately 92.4% of AVCC in series with 195[Omhs]. So given 3.3VDC AVCC it will be about 3.05Vpp across 195[Omhs]. The output will be DC biased at AVCC/2. This works out to about 16ma peak to peak at each output. The amount of bias current will depend of the voltage of the virtual ground."
http://www.twistedpearaudio.com/docs...anual_v1.0.pdf
Old 16th October 2010, 07:11 PM   #14
jcx,
Yup, drew them incorrectly as current. I will use voltage sources with resistors to simulate the intermod sources. Thanks!
I use 15.612mA p-p for the simulations run to date (Sabre32 9018 in 4x4 stereo mode). This number is the typ number directly from the 9018 datasheet.
Dave
Old 6th November 2010, 02:09 AM   #15
Just an update on this project. I think I have a reasonable solution for Balanced to SE conversion on the Zen IV for balanced DACS like the Sabre. You can read about it here. Additional details about the circuit are here.
Enjoy!
Dave
To the moderator - I hope I am not breaking forum rules by pointing to other threads like this. It is an attempt to keep from polluting threads with off subject conversations while not repeating a bunch of information in multiple places... let me know if I am. Dave
hi cap or variant psu rocco gibralter Power Supplies 0 13th August 2009 10:55 PM
Tube output stage for Buffalo Saber 32-bit DAC? Curly Woods Tubes / Valves 0 23rd July 2009 02:18 PM
MP3 (Creative Zen) player to USB DAC? carleast Digital Source 2 7th January 2008 01:00 AM
is this an FE-103 variant? Scioneer Full Range 3 12th August 2007 04:11 AM
Zen DAC !?! Tyimo Pass Labs 14 24th October 2005 05:52 PM
Copyright 1999-2017 diyAudio
