Old 22nd September 2010, 02:23 AM   #1
Default Power output into 4 ohms
I'm confused , which sadly happens more then I'd like to admit. I'v searched though many threads and through google, but still the answer eludes me. If both the Aleph 3 and Aleph J operate in single ended class-a mode, why does one double it's power into 4 ohms and the other halve it's power.
Aleph 3 60w into 4 ohms
Aleph J 13w into 4 ohms
Thanks for any input
Dave
Old 22nd September 2010, 02:37 AM   #2
tinitus is online now tinitus  Europe
maybe only in AB, and not classA
Old 22nd September 2010, 03:01 AM   #3
Formerly Thanh1973
Melon Head's Avatar
Its all in the Aleph current source setup.
You can adjust it if you want.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need."
Old 22nd September 2010, 06:31 AM   #4
Ok, great. Thanks for pointing me in the right direction. I found the article "Zen Variations - Part 2, The Penultimate Zen’s Current Source" It's a little late for a read now, but the title sounds promising
Old 22nd September 2010, 10:22 AM   #5
RIP
The different sections of the Aleph amps are quite interchangable if you understand the different functions being used. I've just finished up a pair of monoblocks optimized for 4 ohms using the front end of the J and the output section quite like the 30 except with 3.6A bias and 55% AC current gain. It's quite easily done but does change the original design parameters so I just call them Alephs. They have bags of current capacity for difficult loads.
Old 22nd September 2010, 05:04 PM   #6
The one and only
Nelson Pass's Avatar
You can make an Aleph deliver beyond the Class A region,
but it's not pretty.
Wensan built a follower version that does the job - maybe he
will comment here for you.
Old 24th September 2010, 06:09 AM   #7
wensan is offline wensan  United States
wensan's Avatar
Here are the schematic and distortion curves of my SRPP power buffer what I built.
The bias current is about 0.75A.
The AC gain is about 85% in order to let it work in Class AB mode.
If the AC gain is 50%, it cannot work in Calss AB mode.
Old 24th September 2010, 09:07 PM   #8
Formerly Thanh1973
Melon Head's Avatar
Thanks Wensan
The other option worth considering is connecting up Aleph J with BA 2 Output stage.
15 ohms (12 on ohmmeter) with 24 ohms resistor in parallel to bring to 8 ohms McIntosh Man Multi-Way 29 11th June 2010 05:36 PM
finding solid state amp output resistance, ohms j.michael droke Solid State 7 11th January 2010 01:37 AM
Can this set up increase the output power of LM1875 at 4 ohms?? Leolabs Chip Amps 7 25th November 2007 11:29 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
ESP 3A output power at 4 ohms load Freddie Solid State 19 5th January 2004 06:02 PM
Page generated in 0.11170 seconds (71.98% PHP - 28.02% MySQL) with 11 queries
