At last, My Aleph 2+ - Page 2 - diyAudio
Old 7th July 2003, 04:05 AM   #11
Brian Donaldson's Avatar
Starting the next one
The row of holes down the middle is exaust for the fan in the back of the chasis. I shouldn't be needed, but it would be nice to keep the caps inside cool.
Old 7th July 2003, 04:08 AM   #12
The extra holes and grease spots were from r theta test. I wanted to be sure these things would keep cool.
Old 7th July 2003, 11:21 AM   #13
PedroPO is offline PedroPO  Portugal
PedroPO's Avatar
Send a message via ICQ to PedroPO
Nice job!
Your front panel would also be great if you polish it mirror like!
congratulations on you work!
Pedro Oliveira
Old 5th October 2003, 12:48 PM   #14
This forum has been lacking photos of innards lately, so I'll show you what I've been up to. The big ugly IE's hummed and buzzed and didn't give high enough rail voltages, so there out. There was also a lot more supply ripple than I want ( 2.5V ). I called Avel Lindberg and orderd a pair of 1000 va 50+50v toroids. The price was right, but they're made in China. (Not to knock our Chinese members. They They know that they keep the good stuff and send us the trinkets and crap.) Yuck. The wires seem a bit small for 10A but they will only see 5A load.
Old 5th October 2003, 12:52 PM   #15
This layout will give a much cleaner looking inside. I may put a slab of steal under the driver board if I hear any noise from the tramsformer. I'm also going to put air core chokes on the front corners of the Al subfloor the toroid is mounted on.
Sweet home made ground bar, eay.
Old 5th October 2003, 12:56 PM   #16
The peice of l on the back is clamp mount for relays for soft start. Freds will be mounted on the bottom. I have mosfets there now for layout.
Old 5th October 2003, 01:00 PM   #17
PSU has fred rectifiers, 68000 uf 100v monster caps, air core chokes around 6mh 1ohm then 34000 uf 74 v caps (per rail). Should get the ripple down where I want it.
Those are not the chokes. and they will mount flat with nylon bolts the the holes near the corners seen in the other post.
Old 5th October 2003, 01:10 PM   #18
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
My wife leaves town and I can barely keep myself fed and in clean clothes...
When I fantasize how my amps will look when I someday build them...
Old 5th October 2003, 01:36 PM   #19
Djomil is offline Djomil  Serbia
Hi Brian,
I want to ask you something to do for me. Please call my wife to visit you. This is the only way to catch some extra time to finish my Aleph. (he, he, he)
Nice work and good luck to listening your amps.
Greetings from Belgrade.
Old 5th October 2003, 03:43 PM   #20
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Thumbs up Ceci n'est pas une pipe
Very nice and robust looking amp.
You remind me of Magritte, or is it a tipo?
/Hugo
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 24 14th May 2017 11:03 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
