Need advice driving a tube
Old 5th July 2003, 10:16 PM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Question Need advice driving a tube
what is the best way to drive a tube (getter???)
The tube is PL519 and needs 80V DC offset.
At the moment I have a transformer driving a simple transistor stage driving the tube.
Now it is not possible (?) to use a bridged Aleph-x or equal because the tube has only one 'input'.
Should I use a classA circuit with DC offset ?
Or better a bridged supersymmetric circuit and a transformer direct to the tube (How to get the offset ?)
Greets, Bernhard
Old 5th July 2003, 10:44 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Do you have a circuit drawing for that?
Quite a bit of solid state parlance for a tubeguy like me but I assume you want to provide a -80VDC bias to the controlgrid of that penthode?
Do you use it triode-strapped?
There are several ways to go about this, one of them is simply using a separate bias supply.
Keep in mind that tubes don't come in complimentary pairs so you'll need some trickery if you need a PP drive/output.
Here you can resort to a SEPP configuration as used in OTL amps, it's not perfectly symmetrical by nature but has the advantage of nulling any DC offset at the output...
But again you'll need a dual voltage rail of about +/- 170VDC.
This goes some way into tube territory but a lot of similarities exist in the sand amp field where often the same topologies are used.
Unfortunately I'm not familiar with the Aleph circuits but I'm willing to look into what you want to accomplish here and advise accordingly.
Frank
Old 5th July 2003, 11:56 PM   #3
Bernhard's Avatar
Hi Frank,
there is a + 80Vdc offset on the middle grid.
The circuit modulates that 80V, the tube oszillates.
The higher grid is connected to ground and the lower is feedback for the oszillator.
Is there something I can do with that unused higher grid ?
Old 6th July 2003, 12:04 AM   #4
fdegrove's Avatar
Is the circuit meant to oscillate?
Frank
Old 6th July 2003, 12:14 AM   #5
Bernhard's Avatar
The tube yes, but the circuit driving the tube is not of course.
The tube generates HF ( plasma tweeter )
Old 6th July 2003, 12:54 AM   #6
fdegrove's Avatar
All the circuits I know for these plasma tweeter were done completely with valves.
The ones I heard were always generating hiss, one way or another but...and that's the good news: I came across at least some other fellow in Germany who was working on something similar to yourself.
I'll be out tomorrow but if I can trace him, I'll let you know.
P.S. I used to live in Muenchener Freiheit.
Frank
Old 6th July 2003, 04:43 AM   #7
Vaihde is offline Vaihde  Finland
Vaihde's Avatar
http://www.plasmatweeter.de/
http://www.ee.vill.edu/~cdanjo/sitemap.html
there some plasma tweeter links
Old 6th July 2003, 08:13 AM   #8
Bernhard's Avatar
Yes, I know all the links, my question is:
is there a way to use a bridged amp without using a transformer ?
Old 7th July 2003, 06:17 PM   #9
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Interestingly, I have had good luck driving plasma type
tweeters using a high voltage tube to cascode the
smaller Mosfet which serves as the actual gain device.
The Source of the Mosfet goes to ground, the Gate forms
the input pin, and the Drain goes to the Cathode of the high-
voltage high-power tube. The Grid of the Tube is biased at the
appropriate DC value, and the arc of the plasma is driven
by the Plate of the tube. Worked great on Plasmatronics,
and had quite a bit lower distortion than other approaches,
and also better reliability.
This approach is also really effective in driving electrostatic
loudspeakers....
ps. This approach operates great without a transformer,
bridged or unbridged.
Need advice driving a tubeHide this!Advertise here!
Tube amp specifically for driving ESLs bigwill Planars & Exotics 185 14th February 2015 02:13 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 06:59 PM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
Tube advice nubbins Tubes / Valves 3 22nd August 2004 01:18 AM
Copyright ©1999-2017 diyAudio
