I just realized that Nelson published his Zen I/V converter and here is a slight modification to replace the two 10uf caps with a transformer.
![]() LTspice file Jfet Models dave Last edited by dave slagle; 13th September 2010 at 11:12 PM. |
#2 |
Nice. Ideas/suggestions for the x-former? - Pat
www.buyoutdickvitale.com: Pledge money to enable ESPN to get Dickie V off the air |
#3 |
completely logical ;
it's easier for you to make xformers than to make resistors ![]() in any case - to keep things clean and safe - it's wise to decrease PS to +/-12V or - even better - to increase it slightly , and cascode Jfets
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#4 |
Since I make resistors all the time, don't you mean it is easier for me to make transformers than 10uf capacitors :-)
In any event the low voltage drop of the transformer primary allows 15V supplies to be used which I guess could be spun as a green solution nearly halving the energy consumtion of the circuit. I do want to say that outside of spice, this hasn't been tested yet so I'm just throwing it out there for discussion. dave |
#5 |
A line-level transformer intended for push-pull dive and sufficiently gapped to handle the JFET bias currents. Perhaps, one of the amorphous core Lundahls would serve quite nicely, if not inexpensively, I should think.
Ken |
#6 |
sorry - I just didn't saw these 1K resistors still in drains (I'm sorta in hurry - some 8 hours from your time
)what about not having drain resistors at all ? even if Jfet paralleling is necessary to keep L and Rdc of primary as low as possible .....
#7 | |
You have to have the drain resistors so that you are not trying to drive the transformer only from the JFET drains, Their impedance is way too high and would cause both distortion and low-frequency roll-off with the transformer. Those resistors essentially present a 1k ohm source impedance for each primary winding. Another huge advantage of transformer coupling this circuit is the dramatically increased PSRR. The cap coupled version has essentially a PSRR of zero, with respect to imbalanced power supply noise. This is due to the current-source like JFET drain nodes working against us. The transformer coupled version should have excellent PSRR due, again, to the current-source like drain nodes, but this time working in our favor.
Ken |
#8 | |
anyway - just a thought .......
#9 | |
A grounded source FET has no such internally parallel drain resistance and so act only like transconductance elements (high impedance current-source like nodes) as seen from their drains. BTW, this is also true of bipolar transistors and tube pentodes.
Ken |
#10 | |
It sounds as if you may be thinking of creating a transformer specifically for the Zen I/V circuit.
Ken |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.11300 seconds (78.53% PHP - 21.47% MySQL) with 11 queries |
