I have built recently one channel of MF Citation 12 (quasi complementary version) and it sounds great. I want to build now the complementary version using IRFP240/IRFP9240 pair. I have seen on many posts overhere that it is recommended to put a 240R resistor on this type of Mosfet. Refering to Mr. Nelson Pass original schematic (see attached pisture) must I change R18 & R19 from 680R to 240R? Thanks for your help, |
#2 | |
Formerly Thanh1973
If you have a scope you could try even lower. You could probably try as low as 100 ohms. The resistors should be as close to the gate as possible (eg soldered directly to it).
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." Last edited by Melon Head; 12th September 2010 at 08:51 PM. |
#3 |
Will the amp oscillate with lower gate resistance value?
Thanks for your reply. PS: Thanh1973 please see your PM. |
#4 |
The one and only
Maybe. Not much reason to go below 100 ohms, though.
BTW, you actually don't have to get fancy with placing the Gate resistors right on the Gate. I have gone a couple feet on occasion without issues.
#5 |
Hi NP,
I am completly "stoned" by the sound produced by this simple, rugged, 7-transistors design. It works like a charm at the first power up. I will try with lower Gate resistance values. In the quasi complementary version I have implemented Gate resistors in the Gate of IRFP240 (see picture attached). My question: Must I short R18 or leave it like this? Thanks for your help, |
#6 |
Im considering building one of these too.
#7 |
Formerly Thanh1973
That is good to know.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." |
#8 |
Formerly Thanh1973
I will be interested to see which one you like better.
quasi vs comp
#9 |
Yes Tekko go on.
OK Thanh I will report back after completing and listening to the complementary version. Be patient it can be very quick or it can take time No answer for my question in post #5? |
#10 |
I'm not nelson passut it looks like you can remove it since you added the other resistor to the left of the mosfet symbol.
| Help with MF X-A 100R | seve | Solid State | 0 | 26th October 2006 06:47 PM |
| mf e2 | diy guy | Solid State | 0 | 21st May 2006 08:16 AM |
| MF x10v3 | zanash | Tubes / Valves | 3 | 19th April 2006 09:21 AM |
| Mf X-pre | stueyh | Tubes / Valves | 0 | 5th July 2005 07:46 AM |
| Page generated in 0.08954 seconds (80.83% PHP - 19.17% MySQL) with 11 queries |
