#21 | |
Problem with this is you would be stuck with balanced ouput and the input would require 2 extra DACs. R2R DAC chips aren't chip or easy to find these days. If you forgo the coupling caps, the output would be around 0V, I would think that a simple servo filtered below 1 hz or less could null the DC offset and be cheaper than buying a quad blackgates. The lower cost would keep it Zen-like IMO |
#22 |
If you forgo the coupling caps, the output would be around 0 V DC since this is split supplied. Can't see a reason not to DC servo unless you just happen to have 4 expensive blackgates in your pocket
#23 |
Just came across this new I/V stage which looks damn good
I made a .pdf file of the article which I found a little hard to find inside DiyAudio, that could probably be attached on the first post too ![]() Best regards, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe "Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Last edited by nar; 10th September 2010 at 12:27 PM. |
#24 |
#25 |
#26 |
Hi guys,
Two of my favorite topics: UGS and IV converters.....in no particular order! Philippe: since you use the ad1865 current mode is it safe to assume that this chip expects 0V at that pin ? I'm thinking of trying this with a 1738 ( in a Shanling CD Player ) which expects 2.5V at the current output pin. Just to compare with a Drek conversion i did with Zen-Mod's precious help I made a mother board for IVs and PSU just so i could test different solutions....here is the chance. Not that i'm unhappy with what i got but DIY is an itch that doesn't go away......... Late edit: I'm curious about the UGS solution by will invest my effort on the present ZEN IV. Last edited by CeeVee; 10th September 2010 at 02:01 PM. |
#27 |
Maybe some of us, actually a lot of us don't like the sound of heavy NFB. I would say Mr PA0SU that this isn't the place to Pimp your website. You are kind of insulting a highly regarded designer and many of us take offense.
And Thankyou Mr Pass for sharing this new design with us, we do appreciate it. |
#28 |
Hi guys,
Two of my favorite topics: UGS and IV converters.....in no particular order! Philippe has posted a UGS based IV in the article coments,since one has to use use the ad1865 ( in his particular case ) current mode is it safe to assume that this chip expects 0V at that pin ? I'm thinking of trying this ( ZEVN IV ) with a 1738 ( in a Shanling CD Player ) which expects 2.5V at the current output pin. Just to compare with a Drek conversion i did with Zen-Mod's precious help I made a mother board for IVs and PSU just so i could test different solutions....here is the chance. |
#29 |
#30 |
Very nice, loved the D1 for long time . Will try this as soon I will find a nice usb or spdif dac with current output .
Any suggestions ?? |
| Zen I/V Converter | Nelson Pass | diyAudio.com Articles | 13 | 19th June 2011 11:04 PM |
| FS: Big Zen Amp, Zen 4 stuff, misc. | picker | Swap Meet | 7 | 11th November 2007 12:06 AM |
| Zen & Zen Variations-Part.2 | billy | Pass Labs | 1 | 7th August 2002 06:24 PM |
| Bride of Zen or Balanced Zen Line Stage? | Mach_Y | Pass Labs | 9 | 28th November 2001 11:07 PM |
| Zen or Bride of Zen as Headphone AMP? | Hauke | Headphone Systems | 5 | 2nd October 2001 06:33 PM |
| Page generated in 0.12065 seconds (80.01% PHP - 19.99% MySQL) with 11 queries |
