Zen I/V Converter
Zen I/V Converter
Old 10th September 2010, 06:35 PM   #41
juma is offline juma  Germany
juma's Avatar
Originally Posted by bogdan_borko View Post
You missed 10K/4n7 on output , they are the load too!
4n7 makes a LP filter together with drain resistors (1k). 10k is not functional part of the circuit. It just represents the possible Zin of the next stage.
Old 10th September 2010, 06:38 PM   #42
Melon Head is offline Melon Head  Australia
Banned
OK just to keep you happy.
Here is results of ZEN IV with 10k resistor and 4.7nF.
Old 10th September 2010, 07:08 PM   #43
Banned
OK let see what the elephant on the dance floor is doing.
Need I say this design kicks **** (Thats *** for my American friends)
Old 10th September 2010, 07:32 PM   #44
Banned
Well the Zen IV could also be classified as an opamp. I was referring to IC opamps.
I have done simulations if you are interested
see here
http://www.diyaudio.com/forums/pass-...converter.html
Old 10th September 2010, 10:01 PM   #45
Banned
Balanced Zen IV
FFT of 4Vpk into 50k load
Old 10th September 2010, 10:53 PM   #46
Banned
That balanced fft is a mistake.
The correct balanced fft is below.
Old 10th September 2010, 10:56 PM   #47
Banned
OK when are the pcbs available for purchase.
I will definitely be purchasing.
Old 10th September 2010, 11:22 PM   #48
masag1 is offline masag1  Germany
Originally Posted by juma View Post
How about using 0.1uF instead of bulky 10uF? It's possible if the ZEN I/V is loaded by B1 running at approx. +/-10V (it's easy to scale down from +/-30V). Additional benefit is higher drive capability.
That is a quite good idea, juma!
I have a hypno board left (wise idea to buy some more).
How shall I do the down scaling? Just change the resistors for the same current as with 30V?
Greetings
Sam
Old 10th September 2010, 11:59 PM   #49
juma's Avatar
Originally Posted by masag1 View Post
...How shall I do the down scaling? ...
RC combo is the easiest way to do it (like R1/C1 or R2/C2 in ZEN I/V schematic). For example:
I make my buffers with BF862 running at 10mA. We want to loose 20V. So, we'll need 2k resistors rated at 0.5W at least. C member can be usual 220uF or less.
R2 sets the DC offset, buffer's Zout is approx. 50R. Schematic would look like this:
Old 11th September 2010, 01:04 AM   #50
rsdio is offline rsdio  United States
Originally Posted by regal View Post
Problem with this is you would be stuck with balanced ouput and the input would require 2 extra DACs. R2R DAC chips aren't chip or easy to find these days.
I do not understand why extra DACs would be needed (did you mean 2 total, or 2 extra? 3?).
Current-output DAC chips often have two outputs; each is a complement of the other. When the sample bits are loaded for conversion, each bit switches a fixed current to one or the other output, and thus the total current through the chip remains constant - and that's much better than having the total current load on the supply change frequently.
In other words, with a complementary current-output DAC, only one chip is needed.
Zen I/V ConverterHide this!Advertise here!
Zen I/V Converter Nelson Pass diyAudio.com Articles 13 19th June 2011 11:04 PM
FS: Big Zen Amp, Zen 4 stuff, misc. picker Swap Meet 7 11th November 2007 12:06 AM
Zen & Zen Variations-Part.2 billy Pass Labs 1 7th August 2002 06:24 PM
Bride of Zen or Balanced Zen Line Stage? Mach_Y Pass Labs 9 28th November 2001 11:07 PM
Zen or Bride of Zen as Headphone AMP? Hauke Headphone Systems 5 2nd October 2001 06:33 PM
Copyright ©1999-2017 diyAudio
