Balanced F5 question
Old 12th December 2010, 11:23 PM   #691
Melon Head is offline Melon Head  Australia
Banned
You are probably right. I have not personally done the measurements.
Just reporting back what friends in the industry are saying.
Having said that, the applications where these failures occured were not at high temps (probably lower than 55 degrees)
Old 13th December 2010, 05:27 AM   #692
EUVL is offline EUVL  Europe
With 2 caps in parallel for each stage of the PSU, I think the 4A each (total 8A) ripple current of the 105°C caps is a bit tight for an amp which is biased at 4A Class A. I would at least use the 6A ones for the C after the Tx.
Patrick
Old 13th December 2010, 03:42 PM   #693
fitzfish is offline fitzfish  United States
All,
Just wanted to let those in the first transformer buy know that all payments have been received and production will begin at SumR for these. Once complete, we will receive notice and I will post here so that everyone knows they are on thier way. Many thanks to SumR for the support and product.
Dave
Old 13th December 2010, 04:45 PM   #694
I did some more search on caps today and found these quite useful.
Patrick
Old 13th December 2010, 04:49 PM   #695
There are some more cap types with even better specs, but they seem difficult to get :
http://www.krummer-kondensatoren.de/...11lc_411lc.pdf
http://www.panasonic.com/industrial/..._aec_ts-uq.pdf
http://www.panasonic.com/industrial/..._aec_ts-hc.pdf
Krummer is sold by THEL as audio specials :
Elkos ultra low induktiv
Patrick
Old 13th December 2010, 07:10 PM   #696
Banned
Hi Patrick could you give some back ground on these graphs.
It looks like for 85 degree caps at 2A and 60 degrees you get 12000 hours of life.
And for 105 degres caps at 2A and 60 degrees you get 100000 hours of life - that's almost an order of magnitude better (ie about 10x better).
This seems to agree with what my friends have been saying about 85 degree caps (crap).
Thanks Patrick for digging this up.
Old 13th December 2010, 07:29 PM   #697
The Y-axis is actual ripple current / rated ripple current.
As you can see in catalogs, the rated ripple current for a 105°C cap is quite a bit lower than that of the equivalent 85°C cap, whereas the actual ripple current depends on the application and is thus the same for both cases.
Patrick
Old 13th December 2010, 07:32 PM   #698
Banned
Thanks Patrick
OK it looks like, for 85 degree caps 50000 hrs at 60 degrees at max rated ripple current (I/I =1)
And for 105 degree caps somewhere between 250000 hrs and 100000 hrs at 60 degrees and max rated ripple current (I/I=1)
So, somewhere between 2 and 5 times better for 105 degree caps at max rated ripple current and same operating temp (60 degrees). This seems about right
And about 8 to 10 times better for 105 degree caps at double max rated ripple current and same operating temp (60 degrees).
Old 13th December 2010, 08:04 PM   #699
Banned
Best 25V TS-UQ with dimensions 30mm x 50mm, 47000uF has 8A ripple current at 85 degrees
Best 25V TS-HC with dimensions 30mm x 50mm, 39000uF has 5.8A max rated ripple current at 105 degrees
Trying to make sense of all of this. Let's say we run both caps at 5.8A at 60 degrees.
That will be I/I=1 for TS-HC and I/I=0.725 for TS-UQ.
So, TS-UQ will give somewhere between 100000 hrs and 50000hrs of life at 5.8A and 60 degress.
And, TS-HC will give somewhere between 250000 hrs and 100000 hrs of life at 5.8A and 60 degrees
Old 13th December 2010, 08:10 PM   #700
massimo is offline massimo  Italy
New Pana TS caps
The question is: how good are "compact" (-30% in size) caps compared to std sized ones?
Balanced F5 questionHide this!Advertise here!
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 - Antek 4218 Wiring Question vdi_nenna Pass Labs 17 7th May 2011 12:05 AM
F2 and F5 heat question trusound Pass Labs 14 1st July 2010 02:28 PM
F5 Output Connection Question rtate Pass Labs 1 5th January 2010 11:58 PM
question re: sony ps-f5 portable turntable voicegyrl The Lounge 0 31st July 2008 09:36 PM
