#681 | |
You're right! 1st link TSHA 22mF/25V d 30mm, 2nd link TS-UP 22mF/35V d 30mm (same value but TS-HA d 35mm I have some pieces on my desk) |
#682 |
Sometimes it's worth looking carefully first.
![]() There is no reason to have to have TS-HA. Some 85°C caps lives very long, unless you are listening to music over 8 hours everyday. And the two ends of the heatsink are hardly over 50°C, near to which is the caps are placed, to the immediate left & right of the main PCB. Take a look at the lifetime specified for e.g. Vishay BC 056 series (85°C) : VISHAY BC COMPONENTS|2222 056 46223.|CAPACITOR, 22000UF 25V | Farnell United Kingdom http://www.farnell.com/datasheets/15301.pdf "Useful life 85°C 12000 hrs." "Useful life 40°C 210000 hrs." For EPCOS, you may choose B41231A5339M000 : https://www.buerklin.com/datenblaetter/D097790_TD.pdf http://www2.mouser.com/ProductDetail...zkPvoelrzp0%3d which is 33000uF and has one of the highest ripple current at 120Hz that I have seen for that size. Patrick . Last edited by EUVL; 11th December 2010 at 02:54 AM. |
#683 |
The above link to Mouser is incorrect (wrong voltage).
This is the correct one : EPCOS|B41231A5339M000|KONDENSATOR,SNAP-IN,25V,33000UF | Farnell Deutschland Patrick |
#684 |
At a glance.
Feel free to propose more alternatives. Patrick |
#685 |
Banned
Nippon Chemicon KMH
EKMH250VSN223MR45S Ripple Current 4.04A at 105 degrees C Last edited by Melon Head; 11th December 2010 at 07:45 PM. |
#686 |
question is, are 105 C any better than 85 C, if temperature stays below 60 C at all times ![]() but BC 105 C have slightly larger diameter than 85 C are they double shielded, or is it because they hold more electrolytic, or both ? is it about cooling, or purely chemical, or both ? |
#687 |
#688 |
I have good experience with BC 056, so I would not hesistate to use them again.
But on pure spec., the EPCOS is quite impressive. And it is 33000uF. Patrick |
#689 | |
Banned
They have never had to replace a 105 degree rated cap (except in the case where the caps were over 20 years old). The rated capacitance also tends to drop more with heat in the 85 degree parts. If you can get them cheap I wouldn't hesitate in using them but if the price difference is small go for the 105 degree parts. |
#690 |
Doesn't that depends on the temperature that the caps will see in its service ?
For industrial applications (e.g. automotive) where 80°C ambient is not unusual, I can image that it makes a real difference. But in our case, it hardly sees 55°C .... Anyway, plenty of choices for the same standard size. Patrick |
| F5 bias question | richD | Pass Labs | 12 | 4th March 2013 12:57 PM |
| F5 - Antek 4218 Wiring Question | vdi_nenna | Pass Labs | 17 | 7th May 2011 12:05 AM |
| F2 and F5 heat question | trusound | Pass Labs | 14 | 1st July 2010 02:28 PM |
| F5 Output Connection Question | rtate | Pass Labs | 1 | 5th January 2010 11:58 PM |
| question re: sony ps-f5 portable turntable | voicegyrl | The Lounge | 0 | 31st July 2008 09:36 PM |
