Balanced F5 question
Old 10th December 2010, 06:37 PM   #671
massimo is offline massimo  Italy
Could you pls anticipate how many caps (and value) in the P.S. for each channel? Just a rough idea....
thanks
Old 10th December 2010, 06:46 PM   #672
EUVL is offline EUVL  Europe
If you were to follow my layout 100%, then you would need per channel 8 pieces of either :
Digi-Key - P6591-ND (Manufacturer - ECO-S1EA223DA)
or
Digi-Key - P6921-ND (Manufacturer - ECO-S1VP223DA)
depending on how much voltage margin you want for the caps. Both will fit.
So for a dual mono build, you need 16 of them.
You can also mix, 35V before the regulators, 25V after. In that case, then you want 8 each.
And I would buy 10 each to allow some matching.
But early days. Please wait till AR2 & Co have built & reported.
Patrick
Old 10th December 2010, 06:51 PM   #673
Horio is offline Horio  United States
Horio's Avatar
Boy the prices of those 25V TSHA's really drop when you buy 200 of them. Might have to get some sort of group buy going (savings of $32 per person).
Old 10th December 2010, 06:59 PM   #674
Yes, group buy makes sense. That's why I call for patience.
Also a good cap is Vishay BC components Series 056. 22000uF, 25V.
Any 10mm-pitch snap-in capacitors up to diameter 30mm & height 50mm will fit.
So many choices, including EPCOS (previously Siemens), ......
Patrick
Old 10th December 2010, 07:11 PM   #675
Horio's Avatar
If there is enough interest, I'll try and organize a group buy on big capacitors and maybe some of the other parts as well. I'll wait until after the prototyping is done though.
Old 10th December 2010, 07:21 PM   #676
Patience.
There are enough other parts for GB's.
Patrick
Old 10th December 2010, 07:26 PM   #677
JBdV is offline JBdV  Netherlands
dumb question:
would a DAC with a balanced output driving a DCB1 balanced buffer be a good set to hook up to a FX5???
Old 10th December 2010, 07:36 PM   #678
Depends whether you think you have enough voltage gain (i.e. depends on your speaker), and how much volume control you would want.
Balanced DAC + B1 + F5X will get you maximum 20Vrms across the speaker terminals with next to no attenuation.
If you want 6dB attenuation minimum, you are down to ca. 10Vrms.
I would probably want another gain of 3~5, but that is a matter of taste.
Patrick
Old 10th December 2010, 08:47 PM   #679
The Pana suggested by Euvl (22mF/25V-25V) aren't TS-HA (105°) but TS-UP (85°).
The equivalent TS-HA are slightly bigger (diam. 35 mm) and don't fit the max size indicated (30 d x 50 h mm).
Old 10th December 2010, 10:04 PM   #680
Horio's Avatar
When I click the first link, I'm seeing a 25V 22uF TS-HA Cap. Shows an operating temp up to 105C with a 30mm diameter. You sure you aren't looking at the 35V TS-HA?
Balanced F5 questionHide this!Advertise here!
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 - Antek 4218 Wiring Question vdi_nenna Pass Labs 17 7th May 2011 12:05 AM
F2 and F5 heat question trusound Pass Labs 14 1st July 2010 02:28 PM
F5 Output Connection Question rtate Pass Labs 1 5th January 2010 11:58 PM
question re: sony ps-f5 portable turntable voicegyrl The Lounge 0 31st July 2008 09:36 PM
