Balanced F5 question
Old 20th November 2010, 10:42 AM   #591
Bksabath is offline Bksabath  United Kingdom
Banned
Hi there
I have been away for a while but not to far.
Enclosed copy of a first draft of the balanced F5 Triple
loads to do as make second half of pcb fatten & route tracks
Suply voltagge planed at 28V rails so components need sizing up
I have retained Nelson numbering.
AL
Old 20th November 2010, 10:44 AM   #592
could the lead outs from the transformer all be flexible rather than enameled?
regards Andrew T.
Old 20th November 2010, 10:47 AM   #593
EUVL is offline EUVL  Europe
Yes, but my experience is that you don't know what wire you get from them.
So I'd rather cut the enamel wire short and screw on a terminal block at the toroid, and use my own (normally silicon) wire from there.
If you want flexible wires we can ask whether he will do 2 of those as an exception.
Patrick
Old 20th November 2010, 10:51 AM   #594
qusp is offline qusp  Australia
qusp's Avatar
edited , just realized no can, i'll order separately
Old 20th November 2010, 10:58 AM   #595
qusp's Avatar
Originally Posted by EUVL View Post
Total dissipation per channel is 128W. Dropout loss in regulator or CRC 24W. Diode loss 16W. Min power requirement per channel = 168W. Factor of 3 to allow for high ripple current of Class A amp (see NP articles) = 504VA. Actually 0.8% undersized.
http://www.firstwatt.com/pdf/art_power_supplies.pdf
Case design has 350mm overall width. Conrad heatsinks 2x48mm. Some room for PCBs, wiring, etc, 2x50mm. Maximum width (diameter) of Tx = 154mm. Fits most commercially available 500VA Tx with about 5mm space left both sides.
Of course you can make your own decisions. That's why I said exemplary.
Patrick
do remember that richard makes these custom, so if the perfect number is 504va, ask him for 504va, i'm sure he will do it for the same price
Old 20th November 2010, 11:03 AM   #596
I think I can also live with an over-rating factor of 2.976 instead of 3.000.
Patrick
Old 20th November 2010, 11:04 AM   #597
jameshillj is offline jameshillj  Australia
Thanks Patrick, understood - 500 VA.
Old 20th November 2010, 11:07 AM   #598
No, 504VA !!!
Patrick
PS Just pulling your leg.....
Old 20th November 2010, 11:07 AM   #599
I work from the other direction, and unsurprisingly arrive at the same answer.
The 500VA 16Aac transformer can supply 4Adc continuously using ~50% of it's maximum continuous capacity.
4Adc is sufficient to bias one channel of balanced F5x.
regards Andrew T.
Old 20th November 2010, 11:09 AM   #600
Do you still want us to ask flex wires for you (only) ?
P.
Balanced F5 questionHide this!Advertise here!
F5 bias question richD Pass Labs 12 4th March 2013 01:57 PM
F5 - Antek 4218 Wiring Question vdi_nenna Pass Labs 17 7th May 2011 01:05 AM
F2 and F5 heat question trusound Pass Labs 14 1st July 2010 03:28 PM
F5 Output Connection Question rtate Pass Labs 1 6th January 2010 12:58 AM
question re: sony ps-f5 portable turntable voicegyrl The Lounge 0 31st July 2008 10:36 PM
