#581 |
Interest in SumR 500VA 2x15V Transformer for F5X (ca. 100USD per Tx):
The Team 4 + AndrewT 2 ..... ..... Please fill in accordingly. Patrick . Last edited by EUVL; 19th November 2010 at 05:59 PM. |
#582 |
Newbie
The Team 4 + AndrewT 2 Horio 2 ..... ..... Please fill in accordingly. Patrick Last edited by Horio; 19th November 2010 at 08:05 PM. |
#583 |
Pls note that 1x 500VA will be sufficient for 1 channel F5X only or 2 channel F5 standard.
Price indication only and not including postage. Patrick |
#584 |
Newbie
#585 |
The Team 4 +
AndrewT 2 Horio 2 pchw 2 ..... .....
- Fred - |
#586 |
So we'll go and ask for 10 pieces.
I think that'll do for the first round. Some discount. Not too much GB effort to divert the team from development work. Patrick |
#587 |
For those who wants to support their local industry, here is an exemplary specification.
Patrick |
#588 |
Banned
Thanks for the specs.
I will get a quote from harbuch |
#589 |
Please pardon my ignorance here, still catching up on the thread - why is a 500VA, 16A txr required for each channel?
If custom made, would 2 X 300, 400, etc VA units or one larger single unit, if space permits, do the job? I generally use the EI core trannies, but are much larger (and expensive) than the T's.
... jh |
#590 |
Total dissipation per channel is 128W. Dropout loss in regulator or CRC 24W. Diode loss 16W. Min power requirement per channel = 168W. Factor of 3 to allow for high ripple current of Class A amp (see NP articles) = 504VA. Actually 0.8% undersized.
http://www.firstwatt.com/pdf/art_power_supplies.pdf Case design has 350mm overall width. Conrad heatsinks 2x48mm. Some room for PCBs, wiring, etc, 2x50mm. Maximum width (diameter) of Tx = 154mm. Fits most commercially available 500VA Tx with about 5mm space left both sides. Of course you can make your own decisions. That's why I said exemplary. Patrick . Last edited by EUVL; 20th November 2010 at 09:39 AM. |
| F5 bias question | richD | Pass Labs | 12 | 4th March 2013 12:57 PM |
| F5 - Antek 4218 Wiring Question | vdi_nenna | Pass Labs | 17 | 7th May 2011 12:05 AM |
| F2 and F5 heat question | trusound | Pass Labs | 14 | 1st July 2010 02:28 PM |
| F5 Output Connection Question | rtate | Pass Labs | 1 | 5th January 2010 11:58 PM |
| question re: sony ps-f5 portable turntable | voicegyrl | The Lounge | 0 | 31st July 2008 09:36 PM |
