#281 |
I'm surprised that you've become such a proponent of the Hifi2000 cases now, Patrick
#282 |
Only because of impatient people here who cannot wait until December, and already want to order things now.
Of course they may, but then I also don't want to be blamed that the case won't fit their GB components. So a large case measuring so 500x500x200mm will fit anything. ![]() Patrick |
#283 |
I need one more volunteer to cross check my ACAD drawings vs those from bksabath.
Please send me a PM if you have a dwg and Gerber viewer. Thx, Patrick |
#284 |
Patrick, you have a pm.
#285 |
You too.
Patrick |
#286 | |
I think when it all comes down to it, either you don't bother as Patrick mentioned or you trim the resulting amp, as Zen Mod mentioned |
#287 |
one more question with regard to the heat sink calculations. Are you leaving the option for attaching a regulated PSU to the heat sink, or are these calcs just for the amplifier boards?
#288 |
Banned
If you are intending on using a regulated supply, It will have to be in its own separate case with heatsinks.
#289 |
Correct.
Making a larger case with large heatsinks to accomdate more dissipation will make is too expensive to make and to ship. Then it is better to buy commercial ones. You may consider putting the regulator device on its own free standing heatsink within the case. There is not a lot of spcae, but you might manage. If you allow 4V drop & 4A bias, total dissipation is 16W, so the free-standing sink has to be 2W/°C. Something like V 5512G Profilkühlkörper - reichelt elektronik - Der Techniksortimenter - OnlineShop für Elektronik, Netbooks, PC-Komponenten, Kabel, Bauteile, Software & Bücher - ISO 9001:2000 Zertifiziert (75x50x25mm, not small) Patrick Last edited by EUVL; 26th October 2010 at 04:37 AM. |
#290 |
> It looks like measuring current or voltage is perhaps the better way to group the devices, even with a high precision ohmmeter.
![]() > either you don't bother as Patrick mentioned I do bother. > you trim the resulting amp, as Zen Mod mentioned That depends what you trim. You suggest trimming THD. My approach is to trim second (and maybe third) harmonics without getting higher 4th, 5th, ....., before soldering. If THD is the goal, then opamp and high feedback amp (like the Goldmund ?) rules. No point going to Class A. Patrick |
| F5 bias question | richD | Pass Labs | 12 | 4th March 2013 12:57 PM |
| F5 - Antek 4218 Wiring Question | vdi_nenna | Pass Labs | 17 | 7th May 2011 12:05 AM |
| F2 and F5 heat question | trusound | Pass Labs | 14 | 1st July 2010 02:28 PM |
| F5 Output Connection Question | rtate | Pass Labs | 1 | 5th January 2010 11:58 PM |
| question re: sony ps-f5 portable turntable | voicegyrl | The Lounge | 0 | 31st July 2008 09:36 PM |
