Balanced F5 question - Page 17 - diyAudio
Old 21st October 2010, 08:31 PM   #161
Banned
Yeah I am in for 2 cases, to add to my 7 other cases I am building.
If only this was done 12 months ago.
How about having the option of having 2 case designs. That is use the same heat sinks and case dimensions but have two options.
Option 1: Beautiful and expensive
Option 2: Cheap and nasty like mine
By the way I might be able to negotiate a good deal with Conrad as I have dealt with them on several occasions and can speak to him in person. Conrad is 10 minute away.
Old 21st October 2010, 08:47 PM   #162
EUVL is offline EUVL  Europe
Cheap and nasty does not go with the name "EUVL".
I have my reputation to upkeep !!
Someone else might do the low cost version (but not nasty), and I have already gotten him to talk to variac.
The design will take 2 channels of F5X, so not mono-block, and not a tower design (which is exclusively our own, for now).
I am thrilled that so many of you have PMed me to offer help, or to commit to buying without even seeing one picture.
Variac has seen it, and he seems to be reasonably impressed. That is enough reward for me.
We need to do some more organisational work (getting quotes, etc.) before we can tell you more.
But thanh I'll take up your offer. Get us a quote for 100 pcs MF35-151 with 16 blind holes tapped M3x6deep, plus estimated shipment cost to Mark Lai.
Drawing to follow later.
Patrick
Old 21st October 2010, 08:52 PM   #163
Banned
Patrick
Cheap and nasty is just a saying. I didn't mean it literally.
Here are my two cheap and nasty monoblock cases I have on the go for a JLH amp.
I will try and get a quote to today.
Old 21st October 2010, 08:58 PM   #164
Tell us how much you spend on material alone ..., and how much wieght.
Patrick
Old 21st October 2010, 09:16 PM   #165
Banned
OK
It might take a bit of time to find the receipts
Old 21st October 2010, 09:18 PM   #166
smyslow is offline smyslow  Europe
Hi Patrick,
I'm in for minimum one of your case. And of course I will also buy the pcbs and build a second balanced F5, now exactly the design you suggest.
Regards, Uwe
Old 21st October 2010, 09:21 PM   #167
thanh, Check your email.
Uwe, Danke für die Unterstützung, auch schon beim ersten Bau des F5X-es.
Patrick
Old 21st October 2010, 10:37 PM   #168
Horio is offline Horio  United States
Horio's Avatar
Hey Patrick,
Unless your case design turns out really ugly (I have a hard time even imagining that ), you can count me in for at least one case (probably 2).
I can't wait to see it!
Old 22nd October 2010, 01:13 AM   #169
neb001 is offline neb001  United States
Same for me as well
Old 22nd October 2010, 01:39 AM   #170
Banned
The total cost of aluminium (cut to size) to make 7 cases of varying dimensions was $240.
So on average that comes out to about $35 per case.
A conservative guess for the big cases would probably be about $50 to $60 per case (it might actually be cheaper than this).
To do the cases you see in the picture the cost of aluminium would have most likely cost around $25 per case.
I used 10mm for front plate and 3mm plate for top, bottom and back plates.
I will get more detailed info later.
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 - Antek 4218 Wiring Question vdi_nenna Pass Labs 17 7th May 2011 12:05 AM
F2 and F5 heat question trusound Pass Labs 14 1st July 2010 02:28 PM
F5 Output Connection Question rtate Pass Labs 1 5th January 2010 11:58 PM
question re: sony ps-f5 portable turntable voicegyrl The Lounge 0 31st July 2008 09:36 PM
Copyright ©1999-2017 diyAudio
