#111 |
> Yes I am also a fan of the irfp devices.
I am not, but that's well known. We tried an AX100 Toshiba vs IRFP 3 years ago. No comparison !! Patrick Last edited by EUVL; 20th October 2010 at 09:32 PM. |
#112 |
Banned
Thanks Patrick
I will definitely be trying both toshiba and IR devices. |
#113 |
Patrick, would you please explain the PS arrangements in your design?
You told us you're using a 650 VA Xfrm, possibly 12+12 V or slightly higher, and then? Diodes, caps, CRC, CLC, etc. Thank you. |
#114 |
16+16, soft recovery diodes, CRC-Zen 4 regulator-C, 20000uF per C.
Patrick |
#115 |
ZhouFangs offerings:
Value match: $14/pair(1 each), $7/pc for 2SK1530, $8/pc for 2SJ201 Precision match: $16/pair(1 each), $8/pc for 2SK1530, $9/pc for 2SJ201 P-N match: $28/pair(1 each) What option will get me over the line for single point matched as per EUVL’s post 14? |
#116 |
Banned
Update
I did the resistor measurement again with an Agilent 34401A meter and 4 wire kelvin probes. The resistance value I get this time is 0.471 Ohms. I also tried to do the TCR measurement with the better meter and basically got the same result. That is there is quite a bit of noise when you get into the microOhm region so it is very hard to confidently measure anything below 1 milliOhm. All I can say is the resistors are better than 50ppm. I will try TCR again with a 100 Ohm resistor. Sorry if this is off topic, but I thought some people might be interested. |
#117 |
Banned
Just to give you an idea of how good the tolerance is on a 5% tolerance specified resistor (Dale CPF3).
Here are the values of 10 resistors taken at random. 0.470, 0.468, 0.470, 0.467, 0.469, 0.471, 0.469, 0.470, 0.474, 0.474 That is quite a bit better than 5%. Hopefully that puts things into perspective for people. So it shouldn’t be too hard to match resistors to 1 mOhm. Hopefully 1 mOhm is good enough. |
#118 |
thanh,
Try my method. What you are testing is basically the repeatability of the measurement. It does not address different tempco between different resistors at say 70°C. The 5% accuracy normally refers to absolute accuracy (deviation from absolute 0R22, e.g.). Device variation is a lot lower. Patrick Last edited by EUVL; 21st October 2010 at 04:01 AM. |
#119 |
Ask him by PM for NNPP match, and if you want to be perfect than NNNNPPPP match (all to 10mV). He would ask for a premium, which I consider fair. But please refer him to this post. Zhou, I hope you would be kind enough to help F5X builders out by offering NNPP sets without too much extra premium. I am sure your large matching batch can accommodate this without too much problem. Best regards, Patrick |
#120 |
Banned
I will try you method but I have already demonstrated the resistance doesn't change with temperature.
If it does it is below the noise floor of the instrument. Anyway I will do your method. |
| F5 bias question | richD | Pass Labs | 12 | 4th March 2013 12:57 PM |
| F5 - Antek 4218 Wiring Question | vdi_nenna | Pass Labs | 17 | 7th May 2011 12:05 AM |
| F2 and F5 heat question | trusound | Pass Labs | 14 | 1st July 2010 02:28 PM |
| F5 Output Connection Question | rtate | Pass Labs | 1 | 5th January 2010 11:58 PM |
| question re: sony ps-f5 portable turntable | voicegyrl | The Lounge | 0 | 31st July 2008 09:36 PM |
