Balanced F5 question
Old 21st February 2011, 12:52 PM   #1091
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by tinitus View Post
if you want 100% pure classA, it seems to me that both low impedance speakers and balanced design is a bit of a 'pain'
With MOSFET output stages, balanced is always a bit of a pain, Class A or no Class A.
For low impedance loads, Class A is a bit of a pain only if the LSP also has low efficiency.
Plenty examples of high quiescent current level, low power Class A amps for high efficiency loudspeaker systems, both commercial and non-commercial designs.
ZM, stop spitting against the paper.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 21st February 2011, 01:39 PM   #1092
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
ahh, yes
and that we do
but why do I get a reminder of old days when some amps were 'marketed' with their 'music wattage'
hey, Im not trying to be sarchastic, not at all, and I know it may not be quite the same thing
but I still get this..hmmm
but hey, Im doing it too
That's because you cannot sell a 20Kg amplifier costing 5.000$ by advertising their "just" 25w per channel.
Other mainstream manufacturers choose to say the real ratings, but they seem so small that use to show them in a shy and small thypography.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 21st February 2011, 01:45 PM   #1093
R.I.P.
Originally Posted by regiregi22 View Post
That's because you cannot sell a 20Kg amplifier costing 5.000$ by advertising ........25w per channel.
Yes, you can, if you identify your market and tailor your output to satisfy that market.
A bit like JC did with the Blowtorch.
regards Andrew T.
Old 21st February 2011, 01:46 PM   #1094
22KG the pair, at roughly $5000 in the early '90s, for 30W Class A power per channel.
Quite a few sold, actually.
(Oh Dear, these were used Bridged, and MOSFET output stage amps on top of that !)
Old 21st February 2011, 02:11 PM   #1095
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by Melon Head View Post
Sorry if someone has already answered this.
P=V^2/r, Therefore if you double the voltage you quadruple the power. I am not sure if that has answered your question.
Also you get less class A current. That is you get half the class A current compared to a regular F5 biased in the same manner.
yes that answers it perfectly thanks, joules law yes? but how does this fit with ohms law over a set resistance?
nvm, i've been too stuck on ohms law, but we are dealing with reactive devices here and the effect of increased voltage over the fets and speaker is not linear.
back to the books
Old 21st February 2011, 02:19 PM   #1096
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you really like them ......
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st February 2011, 02:36 PM   #1097
When was the last time something really good, and attractive, came out of the Philips lab overhere ?
Look Ma, no spaghetti.
Old 21st February 2011, 04:42 PM   #1098
juma is offline juma  Germany
juma's Avatar
Actually, I prefer straight, short and thick piece of wire instead of false tidiness of endless spaghetti tracks on the pcb...
Old 21st February 2011, 07:58 PM   #1099
Melon Head is offline Melon Head  Australia
Banned
back to the books
Ok to make it simple lets assume no losses.
The best way to do this is with an example.
We have two amps:
A) Stock standard F5 with 20V rails
B) Balanced F5 with 20V rails
Assuming no losses:
the max power of amp A is (20^2)/8 = 50W pk (25W avg) power into 8 Ohms
the max power of amp B is (40^2)/8 = 200W pk (100W avg) power into 8 Ohms.
To determine required current use V=IR or I=V/R
Amp A requires 20/8 A = 2.5A for max Class A power (ie 25W avg) into 8 Ohms, however we only need to bias at 2.5/2 = 1.25A since a push pull amp provides double the bias current
Amp B requires 40/8 A = 5A for max Class A power (ie 100W avg) into 8 Ohms, however the balanced F5 does not provide double the bias so we need to bias at 5 A (thats 2.5A from each half of the circuit)
So a balanced F5 will produce 4 x the power of a regular F5 using the same rail voltages, but depending on the bias current it may not all be in Class A.
There is no reason why you couldn't build a Balanced F5 with 20V rails and a bias current of 2.5A. That will give you 25W Class A and up to 100W in class B.
Hope that all makes sense.
Old 21st February 2011, 08:15 PM   #1100
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
20V rails
I think you mean 24v rails, 20v available.
That's two output pairs
Balanced F5 questionHide this!Advertise here!
F5 bias question richD Pass Labs 12 4th March 2013 12:57 PM
F5 - Antek 4218 Wiring Question vdi_nenna Pass Labs 17 7th May 2011 12:05 AM
F2 and F5 heat question trusound Pass Labs 14 1st July 2010 02:28 PM
F5 Output Connection Question rtate Pass Labs 1 5th January 2010 11:58 PM
question re: sony ps-f5 portable turntable voicegyrl The Lounge 0 31st July 2008 09:36 PM
