New Aleph 1.2's New Aleph 1.2's - diyAudio
New Aleph 1.2's
New Aleph 1.2's
Old 3rd July 2003, 05:38 AM   #1
jewilson is offline jewilson  United States
Send a message via AIM to jewilson
Default New Aleph 1.2's
I am in the process of building - several Aleph 1.2 clones. I call these amp Aleph 1.2 "S" for scrap. The aluminum plate and the heat sinks were all purchase as scrap or salvage materials. The
time labor and to get to this state of completion was much longer than anticipated, however getting there. The heat sinks
were purchased from a metal salvage dealer, who just happen to have a bunch of Nelsonís salvage sinks. The aluminum plate was also purchased as salvage material and cut to size
on 14Ē bandsaw and power miter. Having built these to chassis I now see why other manufactures donít build amps like this, time and money.
In another week or two, they will be off to be anodized and they will be ready for the electronics. All the components are purchased except for the transformers. The bottom half of the chassis is for the transformer and bridge. Beside the two amps pictured, a friend of mine has built another two 1.2's you can check them out on his web site www.mcranepage.com.
Jim W.
Jim W.
Old 3rd July 2003, 06:35 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Nice job.
Your not going to wind your own transformers, are you?
The picture with the wires on the site is totally insane.
What are all these wires good for?
/Hugo
Old 3rd July 2003, 06:53 AM   #3
Taco is offline Taco  Netherlands
Very nice . I see on the webpage that you self anodize the metal parts?
Old 3rd July 2003, 03:47 PM   #4
Default More on Aleph 1.2s project
No, I am not going to wind the transformers, I considering using either a Piltron or Troid Co. about 1.5KV. We looked at doing the anodizing however; we found a local shop that would anodize two complete amps for about $45.
Also, I am looking to build a PCB for Mosfet power distribution, and routing the output signal. At this time I am looking for a good board shop, if you know of one wiling to do small quantities please let me know.
Before the amp go to the anodizer they will be sanded to clean up the finish. This will give it a brushed look.
In addition, I do have Mechanical drawing for anyone interested.
Jim W.
Jim W.
Old 3rd July 2003, 08:17 PM   #5
fcel is offline fcel  United States
I don't know about the mech dwg but is there any more heatsink left that we can buy? and how much per piece?
Old 4th July 2003, 02:40 AM   #6
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
They look great but is that enough heatsinking for a 1.2? Looks like it might accomodate an Aleph 2 though.
Mark
Old 4th July 2003, 03:56 AM   #7
Default Aleph 1.2 build
I do not have name of the shop where the sinks came from. A friend of mine in the San Jose area found them. He purchased enought sinks to build 6 Alephs 1.2's and three Alephs 3's. I believe the picking their or slim now, we had a number of sinks that were warped or had bent fins. I will have with my friend for his number.
The Amp it self is 14 1/2 X in height and the Fins 15" X 15" X 10Ē. The amp transfers some of heat on the top plate, the bottom plate and the sides, so it should be ok. The amp is one giant sink, and with the bottom side plates it larger than the original PASS 1.2 design.
Jim W.
Jim W.
Old 4th July 2003, 04:26 AM   #8
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
are these 6 amps being made for Home Theatre use?? Or for 5
other friends who want killer amps
Just wondering... are you going with 1.5K VA transformers?
Congrats are in order for pulling off this project
Old 4th July 2003, 05:01 AM   #9
Default Aleph Build
The 6 each mono Aleph 1.2 will be used as the main amps for stereo systems. My friend claims he will use the Aleph 3's for his home system, he out there. Ok, I agree that the 1.2 are just a little over the top. With the physical size of the amps it does lend it self to many configurations.
Yep, the transformers will be 1.5kw
The project has been a major deal, cutting the aluminum, and tapping so many holes. I'm hoping that it will all be worth it when the components are added.
Jim W.
Jim W.
New Aleph 1.2'sHide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 24 14th May 2017 11:03 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
