#21 |
Comments coming thick and fast! Thanks guys
![]() I've removed the transformer from the case, but that's as far as I have got as I have been quite busy with 'real' work this morning. I will extend the power lines to and from the transformer a little later, enabling me to fire up the amp with the transformer free of the enclosure. I will report back.... |
#22 | |
Both of the speaker leads connect to the amp pcb as per cvillers diagram. Brass stand-offs: I wanted to use fibre washers when putting this together but didn't use anything in the end. I don't think the holes are conductive, I may be wrong. I haven't tried disconnecting one channel. I'll try it tonight Last edited by Tripmaster; 25th August 2010 at 04:58 PM. |
#23 |
#24 |
Looks like you may have a ground loop within the amplifier.
Proper grounding is absolutely essential.
Frank |
#25 | |
I'll unscrew the screws from the brass stand-offs and place a piece of insulation tape between the board. It will be a good time to try this when disconnect one of the channels. |
#26 |
Jenga Technology is the problem.
"Jenga is a game of physical and mental skill created by Leslie Scott You see, it'll take an awfully long time if you keep those blocks in place!
#27 |
Hi Andrew
Disconnecting channel: good suggestion! I disconnected the left channel, and the right is completely silent. The same applied to the right Hum loop it is
#28 |
Thats great news Richard
![]() Now you just have to work out a way to break it!!! The loop that is ![]() Made a little progress on mine too...buzz still there but hum much quieter...i am going on holiday to cornwall though, so wont be able to do anymore until i come back...i hope you get yours sorted soon. Alon |
#29 | |
![]() I read your post last night, very encouraging Last edited by Tripmaster; 25th August 2010 at 08:44 PM. |
#30 |
Have a great Holiday
...funny how we both have similar hum problems and also similar holidays![]() Alon |
| Grounding Issues | Bonce | Chip Amps | 18 | 9th June 2006 05:00 PM |
| Grounding issues | miguel2 | Chip Amps | 5 | 24th May 2004 06:55 PM |
| Grounding Issues | PaulHilgeman | Parts | 5 | 26th June 2003 09:36 AM |
