Transformer Screen & Signal Grounding Issues - Page 17 - diyAudio
Old 17th October 2010, 11:11 AM   #161
AndrewT is online now AndrewT  Scotland
Originally Posted by mymindinside View Post
how do i measure the dc bias across the output cap?
set your DMM to 200Vdc.
Carefully attach the measuring probes to the two terminals of the capacitor.
C4 & C6 are simply part of a big RC filter between the rectifier and the amplifier.
This filter will not stop the output capacitor charging nor discharging.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th October 2010, 03:57 PM   #162
Originally Posted by AndrewT View Post
You either accept that charging/discharging current passing through your speaker or you fit a speaker isolation switch or relay to provide an alternative current path. You must have a current path. There is no charging/discharging if you leave output open ended during the switching.
Would resistors R13, R15, and R15 (all 47R 3W) provide the current path for charging/discharging if there were no speakers connected? these resistors are connected across the output; i.e. from the negative leg of the output capacitor to ground.
cheers,
mymindinside
Old 19th October 2010, 01:00 AM   #163
I was not paying attention.
These three resistors effectively give 15r in parallel to the speaker load.
At 9W rating they are going to get more than a bit warm.
regards Andrew T.
Grounding Issues Bonce Chip Amps 18 9th June 2006 06:00 PM
Grounding issues miguel2 Chip Amps 5 24th May 2004 07:55 PM
Grounding Issues PaulHilgeman Parts 5 26th June 2003 10:36 AM
Copyright 1999-2017 diyAudio
