#251 |
Banned
I'm wondering wether or not to place a slow running (almost silent) fan inside the case just to stir the air around a bit.
#252 |
Makes zero difference for these diameters with natural air flow, all that counts is the total hole area.
Big holes always have the advantage of more area/airflow for the same diameter total and having to drill fewer.
Looks like Sponge Bob has killed another thread. |
#253 |
Banned
I'm still waiting for any comments about slowly stirring the air inside the case with a fan.
#254 |
Banned
After comments about the mounting arrangements of the chokes in the CLCC filter circuits. I'm now waitng on M8 nylon components to replace the steel ones.
There were some quite heavy magnetic fields around the steel mounting bolts. |
#255 |
Banned
I've also tied both R Hand and L Hand channel 0V to Mains Ground with 12 Ohm 10W resistors as recommended.
Once it is back together I will report on the changes that have been made. |
#256 |
Fan : Use an internal fan running slowly and check inside ambient air temp. 35°C is a max if you want to hold the capacitor bank long life. For the speed, your mileage may vary. Try & Error is also part of DIY's routines
Chokes : Yes, better "air core" 200% Resistors : That should prevent any ground "damage", they could also achieve quieter operation. Anyway, it provides an audio ground connection without creating a ground loop, at least Happy diy, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe "Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright |
#257 |
Banned
Andy, Thanks for popping around this afternoon.
I've got it cracked now. Those tants were awful. I think you will agree, we have now got the sound that Nelson was aiming for. |
#258 |
Hi Andy,
Did you solve / found the source of the problem causing the sssssnake in the grassss ssssound? Was it the tantalumssssss? |
#259 |
This looks good - How did it sound ?
| Any Aleph / X Aleph DIY members in Western Australia? | macka | Pass Labs | 2 | 6th September 2006 12:35 AM |
| Have you build Aleph 1.2... | CJ900RR | Pass Labs | 0 | 1st May 2006 10:49 PM |
| Aleph-X build help | D3 | Pass Labs | 14 | 27th January 2004 08:02 PM |
| Aleph ... which one to build ? | thylantyr | Pass Labs | 6 | 22nd August 2002 02:24 AM |
| Page generated in 0.09508 seconds (87.06% PHP - 12.94% MySQL) with 11 queries |
