Old 17th May 2011, 02:54 PM   #101
generg is offline generg  Germany
generg's Avatar
pumpkin has an amplification of ten, thought for F4 without any amplification. What input voltage does your amp need?
Maybe 1 V only?
and the First Wtt is......a really First Class PSS Idea !
Old 17th May 2011, 03:04 PM   #102
Banned
The noise is there with no input signal applied.
10 x Nothing should be Nothing. Even if the A700 has a more sensitive input ?
The Aleph isn't finished yet, the Shuntky / Pumpkins are being built in preparation for the big day.
Old 17th May 2011, 03:07 PM   #103
generg's Avatar
when your amp has also 20db amplification pumpkins amplification must be reduced.
an older ML I just googled even had 26db amplification.
Old 17th May 2011, 04:08 PM   #104
Banned
All this would help to explain the WHITE NOISE but not the POPPING.
Old 17th May 2011, 04:09 PM   #105
generg's Avatar
what is popping?
poor German...
Old 17th May 2011, 04:14 PM   #106
Banned
Originally Posted by generg View Post
what is popping?
poor German...
The amplifier is making an intermittent "Pop" sound with no input attached and with the volume set to maximum.
Old 17th May 2011, 06:16 PM   #107
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
set gain to 4-5x
try fully open pot , fully unloaded input with any tube preamp (for instance) - and you're looking for trouble
same with Pumpie
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 17th May 2011, 07:06 PM   #108
Banned
As they always say, "You learn something every day".
If I had a signal applied under the conditions mentioned the Power Amp would be pushing over 60W into the speakers so you wouldn't hear the noise anyway. The only problem would be that you would hear the noise during quiet passages.
I'll leave the gain as it is for the time being as the noise may be a function of the increased gain of the A700. I'll see what it is like with the Aleph 4.
Zen-Mod, when you say unloaded input do you mean no signal or shorted input pins?
I would expect an amplifier with shorted input pins to be silent, ie amplifying nothing.
Although I rarely use the amp at full volume there will be occasions when you may wish to do so. I would not expect to hear "pops" from the speakers during the quiet passages...
Old 17th May 2011, 07:21 PM   #109
Zen Mod's Avatar
problem is if you are doing those things* to highly sensitive input , as Pumpkin have ; not thinking about gain , but on sensitivity ... if I'm putting that correctly
* leaving input "open" - without source , where input is projected to work with finite source resistance . that way circ loose programmed gain , because inputs are flapping on breeze .....
I can bet that - if everything is OK - you'll not have any pops or whatever if you connect some source to Pumpkin's input , with pot where it belongs - between source and Pumpie input
Generg ( and few other builders) made similar mistake in past - using Pumpkin set to highish gain , with amps needing just line level for full throttle ..... after setting to moderate/adequate gain , problems were solved
Old 17th May 2011, 07:36 PM   #110
generg's Avatar
Andy do you know how to set the gain to 3-4? One way is to change the feedbackresistor from 100k to 38k-41k, or rise the 10k in the inputs to 25-30k....
Is this correct Zen?
Any Aleph / X Aleph DIY members in Western Australia? macka Pass Labs 2 6th September 2006 12:35 AM
Have you build Aleph 1.2... CJ900RR Pass Labs 0 1st May 2006 10:49 PM
Aleph-X build help D3 Pass Labs 14 27th January 2004 08:02 PM
Aleph ... which one to build ? thylantyr Pass Labs 6 22nd August 2002 02:24 AM
Copyright ©1999-2013 diyAudio
