B5 caught in the wild :)
Old 12th June 2011, 10:46 PM   #31
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by superlian View Post
Will B5 be a good match to my 2 First Watt F4 who need a signal of ca 14 volt?
I presume not - considering needed swing
but - if you use dedicated gain stage between B5 and F4 ................ then it will certainly work as needed
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st September 2011, 10:47 AM   #32
superlian is offline superlian  Norway
Will B5 handle 2x Eminence Beta15A woofers instead of 1x as Nelson Pass describe it in the manual?
I am especially thinking about the 20hz 6db EQ?
Old 21st September 2011, 04:30 PM   #33
Zen Mod's Avatar
yes , why not .
Old 22nd September 2011, 02:31 PM   #34
Jon Ver Halen is offline Jon Ver Halen  United States
It should be fine, as long as the amplifier can provide the power at that impedance.
Jon Ver Halen
Lowther-America
Old 13th February 2014, 08:45 AM   #35
gk7 is offline gk7
A question about the bass EQ:
From the manual "... simple discrete Jfet circuits operated in single-ended Class A
without negative feedback. (The exception is the bass equalization circuit which requires
some feedback to get the curve needed)."
Has anyone an idea what type of circuit is used for the bass EQ ?
Old 13th February 2014, 09:30 AM   #36
Zen Mod's Avatar
that's question for Mithrandir
though - it's usually inverting OP stage , as I learn ages ago , from Elector articles (remember small boxes , forcing bass driver to 1m excursion ? )
Old 13th February 2014, 09:47 AM   #37
gk7 is offline gk7
Well no. Usually this would be a Sallen and Key high pass with a Q of about 2. This can be implemented with an opamp (but I am pretty sure Nelson didn't use one), but it would be wired as an unity gain buffer ( not inverting) anyway. So why is the "B1 type" buffer not feasible here ?
Old 13th February 2014, 10:12 AM   #38
Zen Mod's Avatar
what I meant - you can find on web page of Papa's good SR neighbor , pretty much well known around
look at No.5 - Active Filters
edit : pic linked - look at B case
Old 13th February 2014, 11:19 AM   #39
gk7 is offline gk7
Zen Mod, I know this document, it's a shelving filter and serves a similar purpose but it's not like the high pass filter used in the B5. Take a look at page 4 in the B5 manual:
"You see that it provides a 6 dB bump at 20 Hz and filters out subsonics".
The filter in the B5 is actually like the filter one would use for a B6 alignment.
Old 13th February 2014, 11:55 AM   #40
Zen Mod's Avatar
aha
I misunderstood ......
B5 caught in the wild :)Hide this!Advertise here!
Wild Burro Onken nesha Full Range 58 14th March 2011 11:24 AM
Another insanely wild build trusound Multi-Way 29 26th May 2010 02:02 PM
Now I have caught the bug - next project chrish Tubes / Valves 7 29th July 2007 06:55 AM
