Old 11th August 2010, 11:02 PM   #1
vizion is offline vizion  United States
Default Watt Meter
There was an old thread about power meters. I found this little toy that can do the job nicely.
Atlantic Quality Design, Inc., The PM-150 Audio Power Meter
Old 12th August 2010, 05:40 PM   #2
The one and only
Nelson Pass's Avatar
Usually I only need to go up to 1 watt.
Old 12th August 2010, 10:33 PM   #3
Curious, since First Watt specializes on low powered but great amps. Who makes the loudest, largest Class A amps ever ? Has anyone ever made a 1 kilowatt Class A ? Prob'ly not.
Old 12th August 2010, 10:47 PM   #4
theAnonymous1's Avatar
My 1024W RMS CLASS A+ amplifier.
Too bad we will never see the end of that story.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 14th August 2010, 04:56 AM   #5
Suffering Suckatash !
Old 15th September 2010, 05:24 PM   #6
kzim229 is offline kzim229  United States
I use this gizmo a lot. Sometimes you want to know the current draw.
Amazon.com: P3 International P4400 Kill A Watt Electricity Usage Monitor: Camera & Photo
definitely worth the $20.
Old 15th September 2010, 05:45 PM   #7
Frank Berry's Avatar
The device isn't measuring power if the speaker in and out jacks have virtually zero insertion loss. It appears that the device is measuring the voltage across the speakers and does not take in account the impedance of the loudspeaker.
For accurate measurement of output power, you really need to sample the current going to the loudspeaker using a low value resistor or a current sampling transformer.
Even so, you'll need to be able to calibrate the meter across the audio spectrum based upon the actual impedance of your speaker system at various frequencies.
That is why most amplifier power meters are pretty much useless. They are simply not accurate.
Frank
Old 17th September 2010, 04:27 AM   #8
I have a kill-a-watt. I used it to measure my amp. Constant power draw is 400w.
how to make this esr meter work with 250uA Panel meter dytln_02 Everything Else 2 27th January 2007 10:13 PM
inductance meter from a cheap meter? jarthel Parts 3 22nd September 2006 05:37 AM
Making a milliAmp meter, become a Volt meter redrabbit Power Supplies 11 26th May 2006 07:51 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
Page generated in 0.08021 seconds (81.21% PHP - 18.79% MySQL) with 10 queries
