Building an Aleph 5...two quick questions
Old 22nd July 2013, 09:30 AM   #21
boatbuilder is offline boatbuilder  Netherlands
Default 1st mono aleph working.
after a veeerrryyyy long time i finally found the time to Finnish my aleph 5 mono blocks.
as mentioned i use a 30-0-30v trans.
i did not modify anything so it should be over powered a bit and i think it should run hot.
problem is, it is playing for more than 30 minutes now and i can still put my fingers directly on the fet for as long as i would like without getting burned.
the speakers i use are HEPTA CR-LUX and the first source whas my samsung note. thinking that on full power output from the phone i would get deaf, i was realy wondering where the power went.
the sound is surprisingly good, but it will not play loud or get warm.
now to find out what is wrong and how to post picture's
Old 22nd July 2013, 10:08 AM   #22
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
give it more time to reach temp. equilibrium
check both offset and Iq
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 22nd July 2013, 10:17 AM   #23
by now it is working at 10c above ambient.
checking offset and iq.
think i whill start with my own iq as do not have any idea what you mean or how to do that.
any advise would be more than welcome.
Old 22nd July 2013, 10:25 AM   #24
Zen Mod's Avatar
take this sch as example (many values and functions of parts are explained)
Iq means quiescent current -= measure voltage across one of output mosfet('s) source resistor
then multiply
Old 22nd July 2013, 10:30 AM   #25
oke, thanks. i'll try it.
but first i want to finish the second amp.
i already hear a lot of difference in the sound, the bass is more open, the high is crystal clear.
i agree with most here, we owe papa pass a lot of thanks.
Old 22nd July 2013, 12:57 PM   #26
i think i need to rethink the design of my layout.
if i cut the fet part from the pcb's of the i have enough room to lay them down and room to take measurements. as it is now, i can not reach the source resistor's.
both amp's up and running now.
no hiss or hum, very clean from the first try.
alas i do not have a balanced pre-amp yet so i am working with a passive pre, no, it is just a interlink with a alps BB pot soldered in halfway.
first amp is running for more than 3 hours now and still about 10c above ambient.
i think these amps will never get hot here.
Old 22nd July 2013, 02:27 PM   #27
Default the outside
just thought i would post a pic or 2 of the outside.
front and half of the side's are a black stone the cover is perforated steel.
the feet are old kitchen cabinet handles.
please excuse the bad photo quality.
Building an Aleph 5...two quick questionsHide this!Advertise here!
Very quick Aleph 5 Questions guitvinny Pass Labs 1 23rd July 2007 03:00 PM
2 quick questions JPeitzman Chip Amps 7 22nd July 2007 05:27 PM
2 quick questions Lowjacker Car Audio 3 8th July 2006 03:32 AM
Interested in building an Aleph, tons o' newbie questions JCoffey Pass Labs 25 10th October 2003 05:46 AM
quick questions theChris Multi-Way 0 12th February 2003 04:54 AM
Copyright ©1999-2017 diyAudio
