Power supply connections
Old 6th August 2010, 10:17 AM   #11
Bill Fuss is offline Bill Fuss  United States
RIP
Where did you get the schematic, it cannot be an original Pass design.
Old 6th August 2010, 07:28 PM   #12
MEnsing is offline MEnsing
The schematic is from the Pass Labs X600 and X1000 amplifiers
Old 7th August 2010, 11:45 AM   #13
RIP
The only way I can see it working would be reversing BR4 and disconnecting both BRs from the ground, and taking ground solely from the tied center taps. You eliminate a diode junction from the circuit, doubling the thermal capacity of the bridges. You can do the same thing using just 2 diodes for each trafo but the bridges give you a nice package to bolt to the chassis for cooling.
NP has warned in the past about using the service manuals for construction.
Power supply connectionsHide this!Advertise here!
Better Connectors instead this ordinary DC Power Jack/Plug Connections ? tiefbassuebertr Analogue Source 11 10th January 2014 08:27 AM
Power supply output connections? Tony D. Power Supplies 8 15th December 2009 06:05 AM
Blown fuse when power on without connections internally hew128 Digital Line Level 9 30th August 2009 04:18 AM
Krell KAV 250P - power setting connections aarsoe Solid State 5 14th January 2005 07:54 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 01:30 PM
