F-5 Power Supply part Question
Old 17th July 2010, 08:35 PM   #1
Russellc is offline Russellc  United States
Default F-5 Power Supply part Question
Question: On final assembly before first fire up, and am not sure what to use for C9, as seen in the online Pass Manual for the F-5, on the last page. Its a cap labeled "line" and ".0033" is the only other designation. Is this a disc capacitor, or what? What part should I use and voltage, if any suggestions want to be given?
Variac is on standby
Much appreciated,
Russellc
Old 17th July 2010, 08:48 PM   #2
Sisyphism is offline Sisyphism  Switzerland
interference suppression capacitor - MKP
You can use Kemet R413F13300000M.
Old 17th July 2010, 08:52 PM   #3
I'll see if digikey has it. Will anything else work, I've got a big box of all sorts of caps around here? Thanks for the quick response!
What are the limits of varying from the specified cap?
Russellc
Old 17th July 2010, 08:58 PM   #4
I've got a .0068 Uf @ 400 volts, is that too far off?
Polyester film...
Russellc
Old 17th July 2010, 09:10 PM   #5
WithTarragon is offline WithTarragon  United States
Russellc
No, these are special purpose caps. They are not expensive and they will have a designation of "X" or possibly "Y" on them.
Check Digikey
Old 17th July 2010, 09:11 PM   #6
Even closer, I found .0039Uf 400v "poyester" Will it be a no-no not to use the specified polyprop?
russellc
Old 17th July 2010, 09:17 PM   #7
Check Digikey
I see what you mean. The cap the other poster recommended has 300 volt AC and 1000 volt DC, while the little caps I've got here are only 400 dc. I'll have to order them, they say "M" series?
Russellc
Old 17th July 2010, 09:42 PM   #8
Rodeodave is offline Rodeodave  Austria
hates ground loops
Rodeodave's Avatar
What you want is an X2 suppression Capacitor. They are fire proof and withstand 2.5kV without letting out the magic smoke. X1 is good for 1kV. They're dead cheap and available almost everywhere. Many many devices use them, so if you have an old piece of equipment you might want to look there if you're in a hurry.
Value, as far as I know, is of no big concern, just make sure the cap is specified to be hooked up to the mains.
No affiliation, just came up in a quick Google search:
Line-Filter
FAQ
Gravity - Making the G since 13.7 billion B.C.
Old 18th July 2010, 08:23 PM   #9
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
You can run the amp without them.
Old 21st July 2010, 05:45 PM   #10
there is the definitive answer from the master himself. I have fired up and have both channels at .59 with 0-2 mv offset. Thankyou for all Mr Pass! I'll install the cap later!
Russellc
F-5 Power Supply part QuestionHide this!Advertise here!
Full Modification of CD Transport Audioeca Mephisto - part 1 (Power Supply) pooya Digital Source 6 13th December 2009 07:46 AM
Carlos' snubberized Gainclone Power supply, Part II peranders Chip Amps 77 17th September 2009 10:14 PM
Zen Variations Part 3: regulated supply question Decker Pass Labs 6 4th January 2006 01:25 AM
Power supply question HugoR Tubes / Valves 9 9th November 2005 09:34 AM
Copyright ©1999-2017 diyAudio
