A question about Push-pull class-a
Old 16th July 2010, 12:01 AM   #1
mutter is offline mutter
Default A question about Push-pull class-a
I know the following may be a bit contraversial but I figure the best place to ask here is Mr. Pass' forum as he is the master of Class A
Is not push-pull class A simply "Class AB deeply biased and operating in it's class A bounderies"?
And if that is the case, could it not also be asserted that the term push-pull Class A be a marketing term for that same quoted statement
Before anyone jumps down my throat for saying that note that I'm only talking about the term, not the technique - even at my limited experience I see value in the technique.
I'm just asking as I'm trying to understand what is really gong on compared to what the textbooks are telling me.
Old 16th July 2010, 12:24 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
real PP class A is as long opposite active devices are pushing/pulling - in opposite directions , in exact same amount .
in a moment when amount of pushin/pulling between two opposite devices isn't exact the same - one is decreasing "force" while other is increasing - that's moment of leaving pure class A
there are amps and amps ; some of them are fully in class A , while some other are leaving A , hopping in B .......
that means just one thing ( considering that we are talking about real PP amps solely) that some of them aren't capable , from some reason, to drive own output stage above voltage and/or current needed to jump from established quiescent current/power
nota bene - that's not necessarily bad thing - it can be mater of decision ......
read this , while listening to your fave amp , and you'll be taught how to hear KLUNK!!!
www.firstwatt.com/pdf/art_leave_classa.pdf
edit:
yeah ..... even Papa cheats
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th July 2010, 12:32 AM   #3
juma is offline juma  Germany
juma's Avatar
Sorry mutter, but it's not like that at all - Class A is a working regime of active amplifying device and push-pull is a topology.
Google a bit more or use more liberaly the search button on this forum, learn the meaning of the terms you use - that will help you to really understand what are you talking about, which is not the case right now.
Old 16th July 2010, 12:46 AM   #4
Zen Mod's Avatar
............... Klunk!!! ............
Old 17th July 2010, 03:08 AM   #5
jupiterjune is offline jupiterjune  United States
"Is not push-pull class A simply "Class AB deeply biased and operating in it's class A bounderies"?
I think that is a perfectly true statement. Take a look at the A75 article by Pass and Thagard. It can be an AB amp, but it is designed to be so heavily biased into class A that it can put out 75 watts in class A. Sounds amazing, too. You can turn down the bias pots and run it with just a few watts of bias. But it definitely sounds better with higher bias.
"And if that is the case, could it not also be asserted that the term push-pull Class A be a marketing term for that same quoted statement"
well, I think it really is a matter of how many watts it puts out in class A. If the amp has really small heatsinks and doesn't list how many watts it puts out in class A, then, yeah, it is probably just a marketing term.
I think there is a thread on the forum called "leaving class A" where you might find some good information.
JJ
Last edited by jupiterjune; 17th July 2010 at 03:11 AM. Reason: I don't think my original wording was accurate
Old 17th July 2010, 05:25 PM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
"Leaving Class A" is posted on the Pass Labs website.
It's certainly true that a Class AB amplifier is Class A until
one of the amplifying pair shuts off. It would be legitimate
to call it "Class A" up to that point, but as a marketing reality
it's limited. Many heavily biased 100 or 200 watt Class AB
amplifiers would still only be able to talk in terms of about
10 watts Class A.
Even an X600.6, which qualifies as heavily biased, leaves
Class A at 100 watts or so, and that's a peak figure.
Old 17th July 2010, 05:30 PM   #7
even a single ended ClassA amplifier goes out of it's ClassA region. We call that condition: overload distortion.
regards Andrew T.
Old 17th July 2010, 07:31 PM   #8
Thanks all.
There is definitely a gap between my training and the level that some of these amps are designed at. There is obviously a gap between the simple definitions and the reality of the designs.
I need to learn more...
Old 17th July 2010, 08:04 PM   #9
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
A push pull works in class A as long as it delivers no more than twice its bias current.
A question about Push-pull class-aHide this!Advertise here!
Class B Push-Pull rsumperl Tubes / Valves 31 16th July 2010 07:18 PM
Class A push-pull Nikolas Ojala Pass Labs 5 24th August 2009 01:58 PM
Class A Push Pull with 6L6GC d1camero Tubes / Valves 9 4th December 2007 09:35 PM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 12:52 PM
Push pull class A bias question fragman56 Tubes / Valves 30 24th December 2003 08:23 PM
