Is it possible to realize an A5 with a MOSFET IRFP460 ???
#2 |
Formerly Thanh1973
If you were going to use different devices I would also consider toshiba and ixys.
If money was not an issue, then I would also check out semisouth parts.
"No, this sucker's electrical, but I need a nuclear reaction to generate the 1.21 gigawatts of electricity I need." |
#3 |
Cause I 63 IRFP460 in stock.
The datasheet of the two seem very close. PS: sorry for my English I am French. |
#4 |
That would probably not be a good idea. The IRFp240 has an input capacitance
( ciss ) of 1275pf the ciss of the IRFp460 is 4200pf. so those p460's will be a lot harder to drive. |
#5 |
Is it possible by modifying the DRIVERS,
or compensate our capacity. |
#6 |
IRFP460 will work but it might not be optimal due to the high capacitance.
I used `460s in my first Mini-A and some other experimental SE amps because I have a whole lot of them that I got for free. |
#7 |
Ok I'll try.
Thank you. |
| LM317 in Alpeh amp | ciccio73 | Pass Labs | 1 | 15th December 2009 11:26 PM |
| Alpeh 5 PCBs | Lagroute | Pass Labs | 7 | 6th September 2004 12:08 PM |
| Alpeh 5 pcb | MEGA-amp | Pass Labs | 9 | 30th May 2004 08:35 PM |
| A new Alpeh, | harvardian | Pass Labs | 11 | 12th December 2002 11:35 AM |
| Relays for Alpeh P 1.7 | Miles Teg | Pass Labs | 1 | 6th September 2001 09:49 AM |
| Page generated in 0.07813 seconds (71.01% PHP - 28.99% MySQL) with 10 queries |
