Hello all and good morning!!!
I want to build either an F2 or F5 amp(s) for developing future pieces.. I have a few very wild designs, but want to know how much I can get away with with heat dissipation.. I strive for best practices, but want to know how far I can push the envelope.. |
#2 |
and question is ?
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
How much heatsink is necessary... I'll post my drawing up later today to give an idea were my head is at..
#4 |
Well, there a few problems with your question.
First, the amount of heat sinking is, in part, determined by where you set the bias (the higher, the hotter). You may find diminishing rewards with further increases in bias. This is your call, since someone elses preference will be different then yours. Second, the heat sinking can be more efficient (perhaps considerably more) if a fan is used. Use of a fan has its pros and cons. Third, the amount of required heat sinking is discussed extensively in the F5 threads. The thread(s) is losing its usefulness because of the amount of off-topic discussion, but careful use of the search function can help. Fourth, and this is most important, you need to read the F5 owner's manual. It has been posted and there is a clear description of the heat sinking requirements. No one is going to summarize it for you, you need to read it yourself. Last edited by WithTarragon; 30th June 2010 at 02:16 PM. |
#5 |
The one and only
Go to Radio Shack and spend $30 on one of their cute little
infra-red temperature measurement thingies. It's great for looking at transistors and heat sinks - set it for Centigrade. When it shows your transistor case at 100 deg C, it's too hot.
#6 |
Looks like Sponge Bob has killed another thread. |
#7 | |
There is nowhere you can be that isn't where you're meant to be www.vitalstates.org |
#8 |
Thanks everybody for all the responses.... even Jacco
![]() here is a very crappy and rough drawing of what I want to create.. I call it the Sentinel There will be 2 of these... both will stand about 3 feet tall, you'll be able to see the boards, power supplies etc, as they will be behind etched plexiglass.. The heatsink will be on the backside of the housing.. The majority of it will be painted along with exotic metal laminate inlays here and there..
#9 |
#10 |
Easy peasy lemon squeezy....if you know how to sand cast, weld, and/or machine aluminum.
If not, then your Sentinel head will have to become quite large, your design indicates an underestimation of the heat sink requirement.
| F5 - Antek 4218 Wiring Question | vdi_nenna | Pass Labs | 17 | 7th May 2011 12:05 AM |
| F2,J2,F3,F5 amps and driver layout | Nicola | Pass Labs | 2 | 22nd February 2010 07:21 PM |
| F5 Output Connection Question | rtate | Pass Labs | 1 | 5th January 2010 11:58 PM |
| Building the F2 - teach the newbie please! (one question at a time) | DQ | Pass Labs | 19 | 25th December 2009 07:45 PM |
| F5 bias question | richD | Pass Labs | 8 | 21st August 2009 04:29 PM |
| Page generated in 0.10457 seconds (78.62% PHP - 21.38% MySQL) with 11 queries |
