Aleph X option question
Old 24th June 2003, 06:14 PM   #1
CH2 is offline CH2
Default Aleph X option question
Hi All
I am in process of building a 4 fet per side AX using Hifizen board, as I am not electrical trained, I would appreciate if anyone can help me out on this questions:
1. I intend to use D1A (9.1v zener), Q6A (IRF610) and Q12A (j505). What are the values for R17, R24 and R26 that I should test with?
2. For J1a, and J1b what is the pros and cons of this two alternatives?
CH2
Old 25th June 2003, 09:22 AM   #2
hifiZen is offline hifiZen  Canada
hifiZen's Avatar
I would use J1b. There is not really any trade-off, mostly advantages for using J1b instead of J1a (unless your rail voltage is higher than about +/-25V). J1a just happens to be the original connection used by Grey Rollins.
For R17, you need to know your power supply voltage, and your choice of J1a or J1b. For J1a, start with 1x your rail voltage (eg. 15V for +/-15V supply). For J1b, start with 2x your rail voltage (eg. 30V). Subtract about 12V from that for D1a and Q12a, then multiply by 1000. That should be roughly the maximum value for R17. Example: +/-15V rails, J1b, D1a, Q12a -> (30-12)*1000=18000 ... R17=18k or less. Choice of R17 will have a very small effect on the circuit, so if in doubt, you can use a lower value, or just 0 ohms / short.
R24 and R26 can be 475 and 332, respectively. There is some room here for slightly different values.
Enjoy!
- Chad.
Old 25th June 2003, 10:26 AM   #3
zygibajt is offline zygibajt  Poland
Default To HiFiZen
As I remember You organized group PCB's buy for Aleph X (correct me If I'm wrong).Do You still have any pair to sell.
Also,if You don't meybe You would share the project with me?
If it's done in Protel, I have a production house that can make them from Protel files.Would be great to get any answer from You on that subject.
Bartek
Old 25th June 2003, 02:51 PM   #4
CH2 is offline CH2
Enjoy!
Hi Hifizen
Thanks alot for the above info. I had been reading the various thread for weeks but could not find required data.
Thanks again
Cheers
Hock Hua
Aleph X option questionHide this!Advertise here!
Is it good option? Prabot Everything Else 2 4th June 2008 11:46 AM
I need 12v DC- whats the best option? Rob11966 Tubes / Valves 4 7th July 2007 11:16 PM
Aleph P 1.7 / Aleph 1.2 Balanced IC Question SRMcGee Pass Labs 2 25th March 2007 05:16 PM
Aleph 3, option to get less current temporarely rmgvs Pass Labs 4 19th September 2005 03:03 PM
Copyright ©1999-2017 diyAudio
