ZEN V4 cascoding ??? - Page 2 - diyAudio
Old 26th June 2003, 01:12 PM   #11
nobody special's Avatar
Originally posted by Bricolo
are you slowly telling us that "less is more" is false?
Even Nelson's complicated designs are extremely simple, compared to other amps. What is the problem with inserting a cascode or active current source, if it makes the performance of a simple circuit better?
Steve
Old 26th June 2003, 09:09 PM   #12
Originally posted by Nelson Pass
some will find a smaller gain chip like the 610 more accurate on the top and certainly faster, but may lack other characteristics at the lower frequencies.
Yes , I find this way , turn into bi-amplification and
choose pratically for 2 Zen V2 , one of which is cascoded for the high frequencies speaker .
Old 27th June 2003, 07:42 AM   #13
ergo is offline ergo  Estonia
I'm now in process of thinking all this through in my head....
It seems that IRFP044 is a transistor choise hard to beat here. Most of the other choises seem to have much lower gm and thus lower open loop gain.... but unfortunately this is not available near Estonia (don't you guys just hate such situations)
The 2V on gain transitor seemed a bit low at first but after studing the datasheet I can see why Nelson suggests it. The characteristic is indeed very linear around 2V.
Now some questions.
Nelson and stefanobilliani, have you tried also cascoding the current source and if so, was this helpful?
What would be the things to consider with circuitry providing bias for cascode transistors. I have never before cascoded high current stages and there might be some additional problems to consider.
Ergo
Old 27th June 2003, 10:07 AM   #14
Ergo
Inserting a transistor between the +V and the current source ,----is this a right understanding of your question?----is the same at the use of a source follower-voltage regulator , but ZV4 is already featured for this .
Ergo
There are not too much things to consider I think...;
Just decrease the resistor value in the active portion of the current source if a small chip like IRF610 is used as a gain device( R16 from ZV4)
Old 27th June 2003, 08:53 PM   #15
The one and only
Nelson Pass's Avatar
I have not seen significant improvement cascoding the current
source, but this depends on the nature of the current drive
and/or feedback on the current source circuit.
Regarding the simplicity issue, I regard this as a nice quiding
philosophy, but in reality these projects are exploratory in
nature, and we will wander around the landscape as we please.
If I were to publish the most absolutely simple amplifier I can
come up with and call it a day, what would we do next for
entertainment?
Old 27th June 2003, 08:57 PM   #16
Stefano is offline Stefano  Italy
we would play music and enjoy, master
Let's make something special
Old 29th June 2003, 06:53 PM   #17
The one and only
Good answer.
Old 29th June 2003, 08:11 PM   #18
moe29 is online now moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
how could you get any more simplier than the SOZ?
m.
/ is very interested to see what's in the landsape next! : )
Old 9th July 2003, 01:20 AM   #19
metalman's Avatar
Would this be a correct implementation of cascode for the input and output stages?
Old 9th July 2003, 06:19 AM   #20
For the input , read this post from Zen lightement thread:http://www.diyaudio.com/forums/showt...457#post182457 .
For the output , it lacks a resistor between V+ and the Zener.
I use 7.5v zener
Strange LTP cascoding circuit roender Solid State 3 11th June 2007 10:23 AM
Cascoding X Aleph macka Pass Labs 2 30th September 2005 10:36 PM
On the Subject of Cascoding GRollins Pass Labs 19 17th September 2003 01:32 AM
Copyright 1999-2017 diyAudio
