Old 11th June 2010, 10:43 AM   #1
Default Pass X350 voltage & current
I had got Pass X350 from USA but it can't use in 220VAC.
How do I change primary voltage and current with a new transformer ?
I decide to order Amplimo Transformer but I can't see any voltage and current information of power transformer.
regard
Anadigit
Old 11th June 2010, 01:15 PM   #2
BobEllis's Avatar
X350.5 probably close enough for sourcing a step down transformer, but I bet that you can rearrange the wiring internally to run your amp on 220.
Old 11th June 2010, 02:29 PM   #3
The one and only
Nelson Pass's Avatar
The voltage is are 76 volts c.t. at 16 amps, which produces
+/-57 volt rails.
Old 13th June 2010, 01:24 PM   #4
Default Yeah !
So many thanks PAPA.
Your ampliifer drive my speaker more powerfull.
Anadigit
Old 17th June 2010, 02:47 AM   #5
HiFi Si is offline HiFi Si  New Zealand
Without sounding too ignorant, but isnt there quite a bit more to this than just changing the transformer?
I looked at buying one from Reno a few years ago, but received the advice that the led in the front also plays a role and there is quite a lot more to change and get the biasing right, etc?
I gave up and purchased a new X350.5 and XP10. Love them!
Old 17th June 2010, 08:25 PM   #6
The one and only
No, it pretty much comes down to having the right transformer
taps and changing the fuse/breaker value.
Old 13th July 2010, 01:49 AM   #7
Default Pass Labs X350 voltage change
I have a late model Pass X350 with a single voltage transformer. I am selling it to a buyer over seas and he wants to know if the voltage can be changed to run on 220v. (Asia) Can this be done at Pass Labs or am I stuck? Any help would be great regarding this.
Old 13th July 2010, 02:06 AM   #8
tinitus is offline tinitus  Europe
motionpicture, your question is a commercial affair, and not diy
you have to contact PassLab directly
Old 13th July 2010, 02:12 AM   #9
Thank you, I figured that would be the case as he wants Pass to do the work.
Old 13th July 2010, 02:22 PM   #10
The one and only
I am not aware that there are X350's with only the single
Soft/Slow start - high current - low voltage class A PS for a Pass F5 amp sekess Power Supplies 19 28th May 2011 12:41 AM
CD Output voltage & current Arick Digital Source 4 17th December 2009 02:42 AM
which pass amp "current" amp, which voltage? ShanaVar Pass Labs 4 22nd February 2007 10:32 PM
Matching of Pass Labs X350.5 and Audio Note M3 Kit la1209 Pass Labs 1 1st December 2006 07:12 PM
HI Voltage & Hi current Schottky diode for sale. ohynot Swap Meet 0 11th June 2004 07:41 PM
Page generated in 0.09937 seconds (77.86% PHP - 22.14% MySQL) with 11 queries
