F5 with 2SK2013/2SJ313
Old 27th December 2017, 12:29 AM   #771
PiotrL is offline PiotrL  Ireland
Thanks Fred. I guess I should have dig deeper, regardless that this picture mentions 2sj74 ...
Old 27th December 2017, 10:24 AM   #772
for a small signal jFET the Vgs = zero volts if you want the Current to be Idss and Vds=10Volts and Tj=25degrees C
As you increase the Nchannel Vgs to slightly negative the Id reduces to less than Idss.
This is shown on the graph in the datasheet.
When the Vgs has increased to -1V the Id is down below 1uA
Read Borbely, he is my expert when it comes to FETs.
regards Andrew T.
Old 30th December 2017, 08:10 PM   #773
Thanks Andrew, this is great stuff.
MOSFET are still on their way to Ireland, but I could put together PSU, both cap multipliers and one channel of the amp.
As mentioned previously, I have added socket pins in parallel with source resistors, feedback resistors and also for cap multiplier LEDs and their resistors. This will come handy for experimenting with different setups.
Potentiometers are already set to 0. I have also chosen to use 4.7k resistors in parallel with pots, as it was mentioned earlier in the thread.
Old 1st January 2018, 02:40 AM   #774
konst is offline konst  United States
Send a message via MSN to konst
XRK, what are the resistors you are using for the freewire build?
are you sure?
Old 1st January 2018, 03:21 PM   #775
xrk971 is offline xrk971  United States
xrk971's Avatar
Which resistor are you referring to?
XRKaudio https://www.etsy.com/shop/XRKAudio
F5 with 2SK2013/2SJ313Hide this!Advertise here!
I need Help with my F5.... rtate Pass Labs 15 2nd December 2009 12:07 AM
F5 Help Needed vdi_nenna Pass Labs 84 2nd October 2009 03:33 AM
F5 enough for floorstanders? pathetic Pass Labs 1 15th September 2009 03:45 AM
Thanks for the F5! CBRworm Pass Labs 2 13th September 2009 10:34 PM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 04:50 PM
