F5 with 2SK2013/2SJ313 - Page 52 - diyAudio
Old 5th April 2013, 09:38 AM   #511
I wire my indicator LED that way.
Across both rails with a Zener + resistor dropper.
The closer the Zener voltage to the rail voltage the more quickly the LED dims as the rail voltage drops.
But A nice idea.
How can it be applied to a "normal" speaker delay relay?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th April 2013, 12:08 PM   #512
Anchan is offline Anchan  United States
Well, I think a capacitor can be added in there to create a slower delayed start. So that could create more of a slower "normal" speaker delay relay.
But that would also slow down the speaker protection in case of rail failure, so it would not suit my particular needs. But I think it can be adapted for different applications.
Also, I should clarify that the zener does set the threshold so that the coil only activates at a certain voltage. But it is also needed to set the deactivation point since most relays activate at 70 or 80% of rated coil voltage, but deactivate, once triggered, at only 10%, which isn't so great for a protection circuit.
Old 17th May 2013, 07:57 PM   #513
NicMac is offline NicMac  Italy
NicMac's Avatar
I have acquired and traced a fair number of 2SK2013/2SJ313 in the last period
I have attached a plot illustrating the distribution of Vgs and Yfs measured @0.5A and it looks fairly good. In general the devices are remarkably linear in the 0.3-0.9A range and I look very much forward to build a F5/F5X with these
2SK2013/2SJ313 - IRFP240/9240
Old 18th May 2013, 11:05 AM   #514
The k2013 seem almost random in comparison to the correlation showing for the j313.
Yfs vs Vgs seems to be strongly correlated for the Pchannel.
Is there a science reason for the Pchannel to show this, or is it just chance that the Nchannel are all over the place?
regards Andrew T.
Old 24th May 2013, 02:19 AM   #515
Hello,
Being that Georg is out of PCB's, and he's all the way in Germany too, I decided to make a few boards for personal use.
I used ExpressPCB, and the idea is to go econo all the way, meaning no solder mask, silkscreen, etc. So before I order, I figured I'd see if anyone else would like a pair.
For one pair for myself, the cost turns out to be $93 for the pair. If I get 5 pairs made it comes out to be $35 for the pair ($17.50 per channel).
The board has a few slight modifications. First, I am using a spare set of Vicor switching supplies that I have laying around, so I added an inductor on each rail, which can be bypassed if you don't want to use it. Also, I will be using a small fan, so I added a spot for a regulator and connector for the fan. I also added some caps around the feedback resistors and input, but you can totally leave those off.
Board size is 2" X 6.6".
Open to comments if anything seems weird/wrong with layout. Let me know if you want a set. I plan on ordering probably next week.
Old 24th May 2013, 03:55 AM   #516
I might space the FETs out a little more. Right now they are about 18mm apart, center to center.
Old 24th May 2013, 04:47 AM   #517
Default Revised
Revised slightly longer version
7.7" X 1.875" (195.6mm X 47.6mm)
FETs spaced exactly 1" on center (25.4mm)
Old 24th May 2013, 06:18 AM   #518
NicMac's Avatar
Anchan,
I'm be interested in boards for 8 channels, but I would greatly appreciate provisions for the smd degeneration resistor for the J74 JFET. The trick of EUVL used in the F5X. I would also be using Caddock's for the MOSFET source resistors. Maybe you need some transistors
Nic
Old 24th May 2013, 06:24 AM   #519
NicMac's Avatar
One of the J313 batches I got my on hands are outliers (high Vgs). Everything under control
I my hands they are much more linear and homogenous than the K1530/J201 that I have some experience with
I look very much forward to building a F5X-Juma
Old 24th May 2013, 10:14 AM   #520
Originally Posted by NicMac View Post
Anchan,
Nic
8 channels will certainly bring down the cost, so maybe I can help
I'm not familiar with the smd degeneration resistor for the J74. If you have a value, or better yet a specific part number, maybe I'll throw it in.
As for the Caddock FET source resistors, do you have a specific part #? If I can get them, preferably from Digikey or Mouser, here in the US, maybe I'll use them too.
I do already have the transistors. Got the FETs from member PRAKIT, and jfets from Spencer at FET Audio.
I need Help with my F5.... rtate Pass Labs 15 2nd December 2009 12:07 AM
F5 Help Needed vdi_nenna Pass Labs 84 2nd October 2009 03:33 AM
F5 enough for floorstanders? pathetic Pass Labs 1 15th September 2009 03:45 AM
Thanks for the F5! CBRworm Pass Labs 2 13th September 2009 10:34 PM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 04:50 PM
Copyright 1999-2017 diyAudio
