F5 with 2SK2013/2SJ313
Old 24th February 2013, 06:31 PM   #421
permaneder is offline permaneder  Germany
Originally Posted by generg View Post
Hi permaneder,
they keep you busyyyy......
Hi generg,
nnnnnot really
Old 24th February 2013, 06:49 PM   #422
danny_66 is offline danny_66  Belgium
danny_66's Avatar
OK, now that I looked at the 2SK2013 datasheet I understand the choice of the source resistors better.
The gate−source has a voltage rating of 20V, so with a 20V PS you can keep the source resistors low, but with a 22V PS you can lower the voltage a little that the mosfets see if you use source resistors of 0.68 ohm
Old 24th February 2013, 11:47 PM   #423
jameshillj is offline jameshillj  Australia
Trying NOT to be a PIA, would/could you add a separate 0 volt point for the new added caps (thank you for that) to keep it away from the signal 0 volt point - current flow transients and all that 'stuff'
Old 25th February 2013, 12:04 AM   #424
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
and create a ground loop ?
Old 25th February 2013, 01:25 AM   #425
Georg,
As an Alternative to using the 0 volt point on the pcb as the central Gnd point, the provision for operating this pcb with the central 0 volt point located at the power supply Regulator 0 volt point - an Option, if you will.
Also, if we were to continue this analogy, could you add a further provision to add a resistor between the signal input -ve wire and the pcb's gnd point. - it's a neater way of diong this if it's required - another Option
Sorry to add what might be seen as 'nit picking' things but options are so good to see on pcbs, especially if these don't produce problems.
Old 25th February 2013, 04:25 AM   #426
Originally Posted by jameshillj View Post
Georg,
James,
It is my pleasure . Even though I don't believe that it is necessary, I have isolated signal ground from 0V by RX.
Changes at the regulator boards are not longer possible without extra cost, as my boards producer's preparation work has been done already.
Old 25th February 2013, 05:33 AM   #427
It looks to be a completed design - I think that this pcb, and your supply brd will be around for quite awhile - many thanks.
Old 25th February 2013, 11:29 AM   #428
I think that this pcb, and your supply brd will be around for quite awhile ...
especially if there will be ok 'alternative' mosfet replacements
Old 26th February 2013, 02:42 AM   #429
Rush is offline Rush  United States
Originally Posted by permaneder View Post
James,
Were you able to double up on the number of regulators per board?
Rush
Old 26th February 2013, 06:03 AM   #430
Rush
Hi Rush,
First, the preparation work is already done by my boards supplier. Modifications now would cost additional EUR 45 at least.
Second, it would be necessary to considerably enlarge the boards’ sizes to guarantee a certain space between the MOSFETs to avoid thermal issues. More area = more money.
So, if you really want more current, I suggest to point-to-point wire the additional transistor(s). Be careful to solder the gate stopper resistors very close the transistors’ legs. There is no need to double the small capacitors and Zeners at the drains and sources yet.
Another solution might be the use of IRFP140/IRFP9140 (31A/21A)for example for more current.
Georg
F5 with 2SK2013/2SJ313Hide this!Advertise here!
I need Help with my F5.... rtate Pass Labs 15 1st December 2009 11:07 PM
F5 Help Needed vdi_nenna Pass Labs 84 2nd October 2009 02:33 AM
F5 enough for floorstanders? pathetic Pass Labs 1 15th September 2009 02:45 AM
Thanks for the F5! CBRworm Pass Labs 2 13th September 2009 09:34 PM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 03:50 PM
