F5 with 2SK2013/2SJ313 - Page 38 - diyAudio
Old 19th February 2013, 10:01 AM   #371
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by permaneder View Post
I will also offer regulated supply boards with adjustable output voltages...
wonder if this means I can finally find a purpos for my old 2kw monster trafos
they put out 2x 38Vac
would your regs handle this...safely ?
I have thought about making a 'one for all' power supply
not all amps, ofcourse
extern power supply only for various Pass Diy amps
when big enough it might even power several different power amps together
each amp would ofcourse still have their own lytic power bank
but connections etc are tricky, so i still have doubts
Old 19th February 2013, 10:13 AM   #372
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
when in doubt , use proper sized hammer
whatever you do , golden rule is - max 50W per mosfet case
if you can cool it
same for reg
edit : when you calc size of heatsinks needed to make universal supply from your xformer - then it's cheaper to buy deedicated xformer for each project
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 19th February 2013, 10:20 AM   #373
They will. It might be necessary yet to double the MODFETs depending on the wanted current flow.
What regulated voltages do you require? It wouldn't be wise to feed the regulators with rectified ~ 55V and regulate them down to 20V...24V though. Too much needless heat dissipation.
Old 19th February 2013, 02:44 PM   #374
Rush is offline Rush  United States
[QUOTE=permaneder;3376250][QUOTE=permaneder;3376150
I will also offer regulated supply boards with adjustable output voltages on request. These boards do not include rectifiers and load/buffer capacitors. Please send PM for more information.
One set (2 boards = dual Mono) will cost ~ EUR 20 (minimum order = 15 sets)[/QUOTE]
You are using a different regulator than Juma's, see below.
What is the advantage of your regulator over Juma's?
Rush
Old 19th February 2013, 03:08 PM   #375
very clear answers, thanks
Old 19th February 2013, 03:12 PM   #376
Zen Mod's Avatar
[QUOTE=Rush;3376564]
Rush
Juma's is cap multiplier
Old 19th February 2013, 06:32 PM   #377
[QUOTE=permaneder;3376150]s.
The price per set will be ~ EUR 25 (minimum 15 sets) or ~ EUR 20 (minimum 25 sets) plus shipment from Germany: EUR 3.45 Priority mail (max weight = 500g) + EUR 2.05 registered mail (optional) + EUR 3.55 insurance (optional).
One set = two boards = one stereo amp
Old 19th February 2013, 09:39 PM   #378
[QUOTE=Zen Mod;3376603]
Is cap multiplier not a regulator?
Rush
Old 19th February 2013, 10:16 PM   #379
no, I think its more like a filter
and works like a big cap, just more effective, in some ways
hence the name cap multiplier
I think its also less prone to malfunction
if you dont need a precise fixed voltage it might be better than a reg
you may still need to know how to calculate the correct voltage drop
but what do I know, I only assemble, cross my fingers, and hope it works
Old 19th February 2013, 10:35 PM   #380
Zen Mod's Avatar
think Vgs for mosfet based one , and think Vbe for bjt based one
there is nothing wrong in some reading , Greedy Boyz
I need Help with my F5.... rtate Pass Labs 15 1st December 2009 11:07 PM
F5 Help Needed vdi_nenna Pass Labs 84 2nd October 2009 02:33 AM
F5 enough for floorstanders? pathetic Pass Labs 1 15th September 2009 02:45 AM
Thanks for the F5! CBRworm Pass Labs 2 13th September 2009 09:34 PM
Anybody help with F5? yammy1688 Pass Labs 2 28th October 2008 03:50 PM
Copyright 1999-2017 diyAudio
