#21 |
Yes, long time ago - their inherent non-linearity makes them usable only as a CCS or as a voltage regulators, maybe cascoding devices.
IME, those are sub-optimal parts to use as amplifying devices in audio - maybe in guitar amps or in PA amps or in designs with a lot of NFB... Last edited by juma; 7th June 2010 at 08:05 AM. |
#22 | |
![]() they're simply not up to task , comparing to these ones
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#23 | |
luckily , I'm not an emg .... ing... img.... wtf! not even good at math ![]() ![]() (now - you'll say that toobz aren't good for audio )
#24 |
would the 2SK2013/2SJ313 be a drop in replacement for an F4 Head phone amp?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert |
#25 |
Different bias voltage and you'd have to swap the 0.47 for 1 Ohm.
The F4 has less than unity gain, not very practicle for a headphone amp, imSo.
Not so much,.......if it says "ZM" in the corner. Last edited by jacco vermeulen; 7th June 2010 at 10:38 AM. |
#26 |
I thought low gain was preferable for HP amps, with a standard 2V in out its pretty loud. Besides I crank it up full all of the time so best to keep gain low
![]() Would changeing the bias voltage be a simple adustment of the pot and maybe adjacent resitor that sets the Vref of the TL431?
#27 |
#28 | |
Banned
But I take your point, the toshiba devices are much more linear according to the data sheets. Maybe I should also try the toshibas in the front end of my Aleph 30. I also like the look of 2sj407, not sure if there is a complementary N channel version though. Last edited by Melon Head; 7th June 2010 at 12:36 PM. |
#29 |
Banned
Have you tried the exicon lateral mosfets?
If so how do they compare? |
#30 | |
I tried F5 with old Hitachi laterals (k135/j50) and it didn't sound bad, it was different from original F5 but not better... |
| I need Help with my F5.... | rtate | Pass Labs | 15 | 1st December 2009 11:07 PM |
| F5 Help Needed | vdi_nenna | Pass Labs | 84 | 2nd October 2009 02:33 AM |
| F5 enough for floorstanders? | pathetic | Pass Labs | 1 | 15th September 2009 02:45 AM |
| Thanks for the F5! | CBRworm | Pass Labs | 2 | 13th September 2009 09:34 PM |
| Anybody help with F5? | yammy1688 | Pass Labs | 2 | 28th October 2008 03:50 PM |
