Old 4th June 2010, 12:30 PM   #1
cjkpkg is online now cjkpkg  United States
Default Bi-amping question
If I wish to experiment with bi-amping in order to split the preamp singnal to two signals do I just simply add a parallel L&R output from the preamp?
Preamp is a JFETBOZ.
My desire is to use one amp to drive the tweeters and another to drive the woofers.
As of this point my experiments will include:
JFETBOZ
Aleph Mini-A
F5
Zaph Audio SR71 bookshelf speakers
Thanks in advance
Old 4th June 2010, 01:01 PM   #2
paulb is offline paulb  Canada
You should use an active crossover. Better read this:
BiAmp (Bi-Amplification - Not Quite Magic, But Close) - Part 1
Old 4th June 2010, 01:51 PM   #3
stop.
There may be confusion here.
In the UK, bi-amping means using two amplifiers to drive the passive crossover in the two way speaker.
In the US, bi-amping seems to be used to mean creating an active speaker, using a line level crossover feeding 2amplifers, each amplifier directly connected to a driver with no passive crossover.
Which are you referring to?
regards Andrew T.
Old 4th June 2010, 02:07 PM   #4
using 2 amps to drive the passive crossover in a 2 way speaker.
the mini-A to drive the tweeters
the F5 to drive the woofers
Old 4th June 2010, 02:27 PM   #5
has boz used an output resistor to help stabilse the pre-amp when capacitive cables are used as interconnects?
If yes, then simply add a second resistor of the same value.
Take one feed from each resistor to the power amps.
If there are no resistors required at the pre-amp output then I suggest you add a pair of 51r. Again taking one feed from each 51r to the power amps.
regards Andrew T.
Old 4th June 2010, 04:08 PM   #6
Blues is offline Blues  United States
Lightning In A Bottle
Blues's Avatar
I think it'll sound more balanced with the mini-A (higher gain) driving the woofer (lower sensitivity) and the F5 (lower gain) on the tweeter (higher sensitivity)...well just for kicks try it both ways to find out.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
Old 4th June 2010, 11:07 PM   #7
schematic I used...
Old 4th June 2010, 11:11 PM   #8
Yes, as far as which amp to drive what once I have the preamp sorted out it will be easy to experiment.
The biggest worry I think would be needing a pot on the mini-A due to the higher gain. Not a big deal though...
Old 4th June 2010, 11:12 PM   #9
The one and only
Nelson Pass's Avatar
Better to use B1 buffers with separate gain controls for hi/low
(which makes it a B2)
Old 5th June 2010, 02:56 AM   #10
kzim229 is offline kzim229  United States
Originally Posted by Nelson Pass View Post
Better to use B1 buffers with separate gain controls for hi/ low (which makes it a B2)
speaking of the B2, any estimated time of arrival?
no pressure ...
Simple Bi-Amping QUestion Markgm Multi-Way 25 6th February 2010 08:25 PM
Bi-Amping Question s1977 Solid State 5 17th December 2009 10:25 AM
New to bi-amping sonicman Solid State 11 2nd October 2008 12:24 PM
RAIL power supply / BI Amping question Bifi01 Solid State 4 24th August 2004 06:02 AM
Bi-amping Freddie Multi-Way 21 17th May 2002 03:06 PM
Page generated in 0.09804 seconds (78.72% PHP - 21.28% MySQL) with 10 queries
