I was amazed about the circuit topology in vintage receivers for car audio. Especially Motorola used this topoloy in their hybrid (i. e. tube & solid state) car receivers and therefore Motorola prefer gold plated TO-3 (2N176 and 2N178). Such vintage car radios in Germany are very hard to find. The German brands Blaupunkt and Becker uses at the same aera (1958-1963) push pull concepts (mostly equipped with Siemens TF78 or TF80), but also not OTL.
Are there any experience about sound quality of the Motorola topology? Perhaps it could be excellent with high quality power supplies and after replace the output and driving transformers through high quality versions e. g. from Lundahl. Also very interesting to know it would be, if there are from the same aera, we say between 1958 - 1964 also single ended solid state Motorola/Bendix amplifier components for domestic/hifi hifi/audio Thank you for your comments and informations. More pics, schemas and informations about this vintage products you will find by post #24, #25 and #26 about Vintage Transistors the third jpg file from post #24 shows the schema of Motorola's single ended output power stage with the 2N176. Last edited by tiefbassuebertr; 31st May 2010 at 01:39 PM. |
#2 |
Bendix uses for the power amp stage in their car receivers even by the first "full transistorized" versions still no push-pull Class_B - go to post #35 about
Vintage Transistors You will find in the attached schematic an aditional interesting thing: OTL, but parallel to the speaker output (and instead a boucherot/zobel network) an inductor (transformer outline). The same seems to be by the car radio from the third attached picture What could be the reason therefore? Last edited by tiefbassuebertr; 1st June 2010 at 09:45 AM. |
#3 |
no informations?
#4 |
Ok, well that choke shunts the power transistor collector current to ground to complete the circuit. You don't want a lot of dc current through a speaker coil since that will move the cone up or down such that audio peaks will bottom out the cone. The choke is likely around 100mh in inductance. The text is fuzzy, but it looks like the choke has 1.065 ohms DC resistance. The speaker says (again fuzzy) 6 ohms. I know that speakers like this often have the coil DC resistance about the same as the nominal impedance. So if the collector current was 1/2 ampere ( a guess for a class A 12v audio power amplifier), the speaker might only see 1/6th of that, or about 80 ma.
A better approach that minimizes speaker current even more, and offers a better impedance match is to use the choke with a tap as shown below: Looking for vintage car radio audio output transformer I believe this circuit is from a 1963 Rambler car radio. Anybody have any of these tapped chokes from the 1960's car radio's? I use them as ham radio modulation transformers, for transmitters like the Small Wonders Laboratories Retro-75 AM Transceiver. Jim WD5JKO |
#5 |
thank you for this explantation. By reading this I note, that there is no serial high pass capacitor in use for DC blocking - that I have overlooked completly. Without such capacitor and loudspeakers, which can tolerate a certain amount of DC components, the aim of the coil I understand.
| Single-Ended Class-A Audio Amplifiers | shaan | Everything Else | 32 | 4th September 2009 02:42 AM |
| Pure Class A Single End Amplifier Idea! | Dxvideo | Solid State | 91 | 1st September 2008 10:54 AM |
| 5814 Raytheon Windmill Getter late 50's | bluemike01 | Tubes / Valves | 3 | 10th December 2007 05:20 PM |
| Threshold Audio gold plated boards | nellson | Pass Labs | 0 | 22nd August 2006 08:23 AM |
| Anyone play with the Zen Single-Stage Single-Ended Class A? | Rino odorico | Pass Labs | 13 | 29th August 2002 09:01 AM |
| Page generated in 0.09586 seconds (74.95% PHP - 25.05% MySQL) with 11 queries |
