Hello
I whant build Pass Aleph 3 and i whant to know some things On the board i must put 220uF electrolitic capacitor but i dont know whitch voltage ( i think that 25V be just fine ) and i whant put nichicon KZ 220uF/25V or be better to put 220uF/50V Can someone say another capacitors ( black gate, elna silmic or vishay bc or something else whitch be better) Resistor 0,47Ohma must be 3W or 5W i whant put mills ressistor 5W 0,47Ohma ( some sugestion please ) I whant make power supply with 2 toroidal transformer 2X18V 300VA it is enough. I will use panasonic 22000uF/35V ( 4 for chanel ) without R or L between capacitors any advice is welcome many thanks |
#2 |
Hello again
i have another one question whitch heatsink ( from fischer elektronik or someone else ) you prefer for aleph 3 thanks |
#3 |
Better prefer 220uF/50V elec. capacitors, because 25V is the rail voltage and you will be on the limit using 25V capacitors. Regarding the resistors you can use anything from 3W and up. Better look for not inductive resistors. As for the power supply the transformers and the capacitors you want to use would be ok (if you manage to find 22000uF/50V it will be better for longer life and reliability). Don't forget to use inrush current limiters (CL-60 thermistors) in series with the transformers primary. Happy building Thanasis |
#4 |
Thanks for replay
now i must see what heatshink type i be use any assistance is kind |
#5 |
Hello its me again
i need help that i chose heat shink i think something from fisherelektronik or you people know something else and link to shop of heatshink thanks |
#6 |
it's easier that you make little research what's already available of fisher heatsinks in your country then inform us here , so we can help you to choose
in any case - you need 0,25K/W piece per channel , taking in account 100W of dissipation/ch and your climate
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#7 |
thanasis hi ! do you have any idea where can i find those thermistors ;(cl60)
#8 |
Hi karajak, look at these links. Prefer RS (more expensive but is a real pain to order from US)
CL-60 GE | Thermistor; 10 Ohms @ 25 C; 5 Arms (Max. | 2508822915 | ????? ?????? ???? RS Online Digi-Key - KC006L-ND (Manufacturer - CL-60) |
#9 |
#10 |
thanasis many thanks !RS
is fine. |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 13 | 27th April 2012 02:13 AM |
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions | tiefbassuebertr | Pass Labs | 0 | 6th August 2009 11:11 AM |
| WTB: Aleph-mini PCBs and transistor set for Aleph 30 | needtubes | Swap Meet | 4 | 6th November 2005 06:29 PM |
| PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers | kristijan-k | Swap Meet | 64 | 12th September 2002 07:55 AM |
| Page generated in 0.10217 seconds (79.38% PHP - 20.62% MySQL) with 10 queries |
