Hi.We know that F5 amplifier has a very good and detailed sound.I want to build a bookshelf speaker.My friend tried some speakers with F5 amp.He says this amplifier is not suitable for every speaker.
I bought Vifa XT25SC90-04 tweeters.Which woofer can you recommend for building a reliable speaker for F5 amplifier(in a price range of about 150$/pair)?Thank you
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components |
#2 |
The one and only
8 ohms with 88 dB sensitivity ought to be fine. The limitation
is simply the 25 watts.
#3 |
Hi, I have the same question. As F5 is recommended for high sensitive speaker. I'm considering to buy this woofer Tang Band W6-789E 6-1/2 rated at 92db 8ohm, but my budget is limited so i'm also considering the Peerless 835004 SDS 6-1/2 ion sale at PE and they are rated at 88db 4ohm. For tweeter I find Peerless 810103 8ohm 94db for a very cheap price at Madisound. This will be my firts diy speaker project. By the way, I'm thinking to build a mtm configuration.
Any inputs will be appreciated. |
#4 |
The one and only
Perhaps someone else has the experience with these drivers
to make a comment.
#5 |
After long hours of research, I manage to find some information on a mtm speaker project with the tang band on PE forum. I can go very cheap, but it seem the tang band woofer will give much more sensitive speaker. Here's some spec of the speaker project:
#6 | |
I think tang band is cheap enough and have good results as i can see on specifications.Do not go cheaper.I think it should be worth building
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components Last edited by umut1001; 2nd June 2010 at 07:39 AM. |
| F5 Parts recommendations | Brian Kingsbury | Pass Labs | 47 | 20th June 2011 03:00 PM |
| 10"woofer Recommendations | sdaudio2 | Multi-Way | 20 | 12th November 2007 12:05 AM |
| Recommendations for 6.5-8" woofer/midrange as a dipole | Samppo | Multi-Way | 11 | 3rd October 2006 12:55 PM |
| Need sub woofer driver recommendations | griff | Subwoofers | 4 | 27th December 2001 06:24 PM |
| Page generated in 0.08710 seconds (75.46% PHP - 24.54% MySQL) with 11 queries |
