Old 22nd November 2011, 06:04 PM   #941
Default B1 in an Onkyo 2nd attempt...
I built this B1 into an old Onkyo case. There is a Goldpoint stepped attenuator in the Recording Level location and the power switch is functional as well.
Old 22nd November 2011, 06:07 PM   #942
6L6 is offline 6L6  United States
6L6's Avatar
Can we see pictures of the inside?
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 22nd November 2011, 06:29 PM   #943
jackinnj's Avatar
[QUOTE=bassnkeys;2791398]I built this B1 into an old Onkyo case. There is a Goldpoint stepped attenuator in the Recording Level location and the power switch is functional as well.
DSC_0099-1.JPG[/QUOTE
I used a Sanyo case -- took contact cement and some aluminum flashing to veneer a new front to it -- this is a good technique for repurposing Japanese stuff. I use a Bessler roller knife to cut the veneer. Have also used black formica.
Old 22nd November 2011, 06:45 PM   #944
I didn't take any pics of the interior... maybe someday when I'm rearranging stuff again. Not much to see anyway... the standard board sourced from Pass mounted sideways down at the attenuator end. I hard wired from the Goldpoint (25K mini-V) to the board. Power comes in at the back on the opposite end and then through the power switch that was already mounted in the Onkyo. I feed it the 18V DC from an old Panasonic wall wart supply for a cordless phone... the Panasonic provides a spot on 18V with no ripple. I bypassed (jumped) the selector switch to simplify the signal path. It sounds marvelous.
Old 28th November 2011, 08:22 AM   #945
just finished it then realized i never cleaned the pcb
Old 28th November 2011, 10:48 AM   #946
DimZ is offline DimZ  Greece
nice ..... like the pot
here's mine dcb1
Old 28th November 2011, 02:06 PM   #947
regiregi22's Avatar
Wouldn't it be better to place the trafo a bit further away from the inputs? It seems to be enough clearance. I love the attenuator, by the way is it a Shallco?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 28th November 2011, 03:53 PM   #948
its a khozmo
Old 28th November 2011, 09:48 PM   #949
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
it's a medical grade shielded transformer, no need for space
Old 28th November 2011, 10:28 PM   #950
i did those wires quick to test it. today i went and cleaned pcb and added a thick copper shield to both cables and rerouted them to make it look cleaner.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2013 diyAudio
