Pictures of your diy Pass amplifier - Page 59 - diyAudio
Old 21st March 2011, 07:44 PM   #581
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Originally Posted by regiregi22 View Post
Is that toroid from Toroidy.pl?
yes indeed, very nice , the amp absolutely dead silent.
Old 21st March 2011, 07:45 PM   #582
CeeVee's Avatar
Originally Posted by Nelson Pass View Post
Ooooooooooh.......
Clean wiring.
...OOOOOh praise from the master...i'm overcome
THANK YOU Nelson for this great amp.
Old 21st March 2011, 08:12 PM   #583
Dmatuszak's Avatar
The Pass A75 and system I built 15 years ago. Preamp is also an actie x-over. Biamp setup with the A75 driving the sats and the Carver driving the subs. Outboard DAC using BurrBrown chips...forgot which ones.
Old 21st March 2011, 08:46 PM   #584
regiregi22's Avatar
Just received two of them a pair of days ago They have an extra wire for the inside shield. They're potted. 500VA 2x25vac
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 21st March 2011, 08:54 PM   #585
CeeVee's Avatar
Originally Posted by Andersonix View Post
I wasn't going to ask, but since NP said it was "clean wiring," wouldn't it have been even better if the transformer had been up front (mag field farther from inputs and pcb) and cap bank at the rear (closer to star ground point, pcb, and load)?
There is a reason for Nelson to make his PCBs long and thin...input is at one end, which makes it easier to layout the power wiring to avoid corrupting the input with noise from AC power.
In this case the input is always in the middle, with trafo at back or front, the rectifiers are in my perspective in the right place for this layout option.
If the trafo was at the back i would have to run 240VAC all the way to the back and wiring would be more messy and difficult.
Anyway, there are no absolutely right options, engineering is the art of compromise...someone said.
The amp is absolutely quiet as is, i hear nothing at all with my ear on the tweeter...so I'm happy.
I would have opted for NP type boards before building, theory dictates it, but practice shows that this solutions works well.
Old 21st March 2011, 09:20 PM   #586
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
If the trafo was at the back i would have to run 240VAC all the way to the back and wiring would be more messy and difficult........
for mains AC there is always solution - either routing it under technical bottom of amp ( perforated one on pics ) or shielded ( as on pics with black bottom )
note that Papa is not loosing sleep about that ....... so that must be illustration of importance ( remember Migty ZM's interpretation of Papa's details - "... good enough " )
I agree that other power routes are of more importance ....
this pic deliberately posted
and then - shielded mains cable
this one - not shielded mains cable , but routed under technical bottom
that black central thingie is just route from static shields to sole safety gnd point on chassis
Flew Over the Cuckoo's Nest :
funny one
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st March 2011, 09:24 PM   #587
udailey is offline udailey  United States
Fugly!
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st March 2011, 09:28 PM   #588
Zen Mod's Avatar
tnx
I know
Old 21st March 2011, 09:36 PM   #589
CeeVee's Avatar
Poiting the way for my next build Mighty ZM ?
Each new amp is new adventure and a learning experience.
I'll try to make my next one better than the last...always.
Edit: I particularly like the "routing" of picture 2....
Old 21st March 2011, 09:39 PM   #590
Zen Mod's Avatar
naah ..... I'm just posting pictures
amps are not important ;
building is .......
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
