#401 |
Not so much,.......if it says "ZM" in the corner. |
#402 |
Passive Aggressive
Look. There is a wire you can see on the floor beneath the caps on the right. There is room UNDER the caps. Probably they are there.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#403 |
Very Nice work! The attention to detail is outstanding. Now I have go back into my project and due some tiding up.
Chad |
#404 |
Yep!....
Trannies are in the cellar , What a fantastic job ............ |
#405 |
Estimated weight: 40kg?
#406 |
I would say higher !!! maybe 50-60 Kg ..........
#407 |
Nice build
#408 |
Nice weight
![]() regards zeoN_Rider |
#409 |
Under the capacitors you find the two 600VA transformers.
You can see it on the picture. The complete weight is 51,4 kg The torobars are cooled because the high current (7A). They are thermally coupled with the U-shaped Heatsink. You see it grey between coils and the Heatsink. The black heatsinks over the coils are for the softrecovery rectifiers. They need good cooling. |
#410 |
Passive Aggressive
I bet even the master is impressed.
Man either those toroids are tiny or the caps are MASSIVE.
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Naked pictures of Pass | Pete Fleming | Pass Labs | 30 | 9th December 2006 06:39 AM |
| My new hifi amplifier (pictures) | Wejp | Chip Amps | 23 | 15th October 2004 12:16 AM |
| Pass Diy High Low Pass Please | macka | Pass Labs | 127 | 2nd March 2004 11:00 PM |
| DIY Pass labs 100watt amplifier. | microwalsh8504 | Pass Labs | 12 | 6th February 2004 07:27 PM |
