Pictures of your diy Pass amplifier - Page 236 - diyAudio
Old 16th November 2013, 04:55 PM   #2351
Originally Posted by AndrewT View Post
The difference in density of the hotter coolant cf. the cooler coolant creates a pressure difference. That pressure difference promotes the flow.
It's the same when an open fire heats the air in a chimney. The chimney draws cooler air into the open fire and vents the hotter air out of the near vertical stack.
The critical part is the requirement for a near vertical stack of warmer coolant. That is what promotes the flow.
Yep.... I used to live in a house with a fireplace chimney that was four stories high. When I opened the flue damper, I'd get a RIVER of cold air streaming down the chimney. Fixed the problem, by "priming" the chimney with a small 120 VAC heat gun (think "very strong hair dryer"). Problem solved, once I got the thermal rise in the chimney...and it was a log better than getting a room of smoke.....!
Old 16th November 2013, 05:27 PM   #2352
Originally Posted by CanAm Man View Post
Minor point.....would that be "by gravity", or by convective flow due to the delta T of the water?
Andrew explained it well.
Higher delta T, gives more pressure difference, and higher flow rate.
So it fits well to class A amps: everything has to be big.
Old 30th November 2013, 10:01 AM   #2353
xLoff is offline xLoff  Europe
Default F5Turbo-X build
I have finally completed my F5Turbo-X build. Special thanks to Nelson Pass and all forum members supporting and inspiring DIYes out there!
-- xLoff
Old 30th November 2013, 10:06 AM   #2354
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
nice
next time - put those Donuts one on top of the other , and you'll have place for cap banks , also put one on top of the other
or - using big additional plate , you can put both Donuts right behind front plate , "vertically"
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th November 2013, 10:38 AM   #2355
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Really well done xLoff!
Bravo
Enrico
Old 30th November 2013, 11:12 AM   #2356
bcmbob is offline bcmbob  United States
Xloff, That last picture prompts me to ask what you are using for volume control. Does what looks like a CD player have that function? I could easily be reading more into that shot than you intended.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 30th November 2013, 12:26 PM   #2357
KatieandDad's Avatar
A power amp doesn't need a volume control. That function is normally performed by the pre-amp.
Old 30th November 2013, 01:07 PM   #2358
Hi ZM and emyeuoi,
Thanks for the feedback.
- This was the original plan, but I was afraid the amp wold be too heavy at the front, possibly tipping over with ~70% of its 25 kilos at the front... I did follow your tip about hiding the AC mains leads though (link).
- Hi bcmbob. It's an Audiolab 8200 CDQ preamp with DAC (ESS 9018) and optional CD drive. One of the few decent preamp - DAC combos with analog inputs I could find.
-- xLoff
Old 30th November 2013, 02:13 PM   #2359
Quite correct, but a playback system usually does.
xLoff - Very nice combo unit. I have about the same functionality in what happens before the F5/BA-3 but spread across several boxes. As stated in the linked review, the sound shaping and control options are virtually endless - particularly with the 8200 PC union.
Very nice system indeed
Bob M.
Old 30th November 2013, 07:39 PM   #2360
-- xLoff
Thank you for sharing the pictures.
Very nice built!
Please be so kind to share also some key specs (Trafo VA, I-Bias, Rail-V, Offset-V, Type of Mosfets, ...).
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
