Pictures of your diy Pass amplifier - Page 23 - diyAudio
Old 16th August 2010, 03:42 PM   #221
Banned
If you choose your heatsinks with a bit of forethought, the case will design itself.
None of us, well very few, want a Nelson Pass Amplifier that looks like an afternoons collection of aluminium and loads of nuts and bolts.
My Metal Workshop consists of a couple of wooden blocks and a Hand Drill.
I opted to build the entire amplifier into an aluminium frame, just pices of 10mm aluminium held together by 50x50x5mm aluminium angle. The bottom is 10mm aluminium plate and tyhe top is 3mm aluminium plate. As a box it looks pretty good but I wouldn't want it in prime position in the lounge. Nor would it dissipate enough heat.
Spraying the top and bottom black and surrounding the chassis with 4 C/Watt heatsinks makes a finished product that is not too far off the original.
I am limited to a height of 250mm for my design, so I have opted for 190mm heatsinks to allow adequate airflow.
I reckon the Duo-Block (ie two mono-blocks in one case) will run at about 60 - 70 degrees.
Old 17th August 2010, 11:28 AM   #222
My realization:
YouTube - ADCOM GFA555 UPGRADE
Ciao
Old 17th August 2010, 11:38 AM   #223
Old 18th August 2010, 05:51 PM   #224
Banned
Anyone following the build of my Aleph4. I have now completed the chassis and attached the heatsinks.
I'm trying to get a decent quote for cutting cooling slots in the top and bottom covers, if not it will be out with the Jigsaw and some good British luck, along with good weather.
I hope that the image is a reasonable size this time and not 2.1MB.
Old 18th August 2010, 07:02 PM   #225
lgreen is offline lgreen  United States
lgreen's Avatar
Andy5112405, nice job! Why don't you start an "Aleph 4 build thread" so that we can all follow your progress (rather than using the pics thread, which is mostly finished projects)?
I like the fact that you are applying lots of elbow grease vs. using a fancy machine shop.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Old 18th August 2010, 09:38 PM   #226
regiregi22's Avatar
I'm following Andy. If you ever open a build thread....
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 19th August 2010, 03:20 PM   #227
Banned
When the project is complete I will look into posting the entire build as a thread. This one has really been an excercise in luck, hence the extremely low build cost. I hope that Nelson himself will agree that the build quality has not been compromised. I would have preferred larger transformers but 2 x 500VA are adequate.
Old 19th August 2010, 03:34 PM   #228
Banned
No wasted real estate here. Possibly an improvement on the original, even if it may run slightly hot.
I've mounted the Input and Ouput sockets on the panel that would normally have the eighth heatsink attached.
Old 19th August 2010, 07:47 PM   #229
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by Variac View Post
Would be a fun contest to have. Pick a Pass amp or First Watt, and everyone makes the cheapest version they can that's not compromised to be worse than a commercial version of the same. I would predict a lot of pots and pans being used for heat sinks! Surplus and E-bay allowed.. But not stuf you have "Laying around" You would need receipts..
Of course looks could also be judged- Balancing cost and appearance..
well - something tells me that is hard to beat "Papa's Surprise" amp
few Donuts , few chokes for choke input PSU , few cans ......... everything from shelf
that's all I need to finish best looking amp
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 21st August 2010, 11:50 PM   #230
Banned
Default Case building
Ok I thought I would post some pictures of my case building efforts. I have cut up enough aluminium so that I can quickly switch between either two wide cases or two narrow cases (ie two stereo cases or two monoblock cases)
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
