Pictures of your diy Pass amplifier - Page 212 - diyAudio
Old 9th July 2013, 07:39 AM   #2111
henryve is offline henryve  South Africa
henryve's Avatar
My problem is not with the quality of the decoupling caps to use. There my preference is usually for the Panasonic FC or FM caps because of their better temperature rating than the Muse caps.
However, how does one determine the best possible value for the decoupling cap? Using an oscilloscope on the rails to see which ones filter left over noise after the smoothing and rectification the best? Listening tests, or both? In other words, how does a designer like NP decide which value to use on a specific circuit, as I have seen values from 10uF to 470uF used for this purpose, and sometimes it is bypassed by another 100nF cap also, sometimes not.
Old 9th July 2013, 08:06 AM   #2112
Tarasque's Avatar
The size of the caps will determine the frequency range at witch the caps have the lowest impedance.
The circuit topology determines the sensitivity of the circuit for power supply impedance as a function of frequency. Hence different circuits use different cap values.
Having looked at various NP designs I see the recurring use of standard component values like 10u and 220u caps. Wayne tends to bypass 220u caps in his designs with smaller caps in the signal and power path. NP tends to do that less.
Personally I favour ballanced designs and they have minimal ground currents as well as easy decoupling from rail to rail for signal current.
Old 9th July 2013, 08:47 AM   #2113
Originally Posted by henryve View Post
........................ I have seen values from 10uF to 470uF used for this purpose, and sometimes it is bypassed by another 100nF cap also, sometimes not.
the electrolytic is NOT BYPASSED.
The HF decoupling is in a different location from the MF decoupling.
These two decoupling types are separated by trace impedance.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th July 2013, 10:30 AM   #2114
henryve's Avatar
Yes Andrew, I understand what you are saying. BYPASSING is the wrong term technically to use. What I refer to is putting a smaller value cap in parallel to the the electrolytic, where each handles a different frequency band if one can put it that way. I was using layman's terminology, sorry for the confusion it caused.
Old 9th July 2013, 01:24 PM   #2115
Einric is offline Einric  United States
Einric's Avatar
I actually did use "Bypass Caps" on my 220uF decoupling caps.
I used 220uF Panny FM's and each one got a Vishay 1837 .01uf.
I don't know what difference it makes but I figured it couldn't hurt.
Old 9th July 2013, 04:00 PM   #2116
Triodethom's Avatar
Is heat that large a factor at the location in question. Well there is some data that the higher temp cap will live longer in the same application but for this one I felt not that big a factor.
Old 9th July 2013, 04:18 PM   #2117
It might hurt a litlle or a lot.
You should test the supply rails for ripple or oscillation when subjected to reasonable step changing loadings.
regards Andrew T.
Old 9th July 2013, 05:10 PM   #2118
Danger Mouse's Avatar
Originally Posted by WalterW View Post
Haha, it's just because I didn't have room for them.
But it gives no problems, I have no hum at all.
But as you can see on the pictures I have made a shielding sub-chassis for the trafos. It is not, as the rest of the case of aluminum, but made of steel plate 2mm thick.
So the input section doesn't see the trafos.
The sub chassis with the trafos and rectifier diodes can be removed separately from the case and also prevents bending the bottom plate from the weight of the trafos.
Walter
Thank you
Same problem in my case not so much room for the trafos.
I will think about this solution... maybe i give it a try
Old 13th July 2013, 05:06 AM   #2119
bcmbob is offline bcmbob  United States
As promised, here is a link to the progress made on the liquid cooling project.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 15th July 2013, 09:37 PM   #2120
12B4A is offline 12B4A  United States
12B4A's Avatar
One last round of amateur graphic design...I did one with the FW logo that was suggested earlier by bcmbob. If I did decide to do the engraving I would do one of these two. However, it's possible I might not choose the F5 to be under the hood for good so maybe just printing it out on a plastic cling sheet would be best. Hell, I could just make sticky cling sheets for each Pass diy amp circuit.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 07:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 01:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 3rd March 2004 12:00 AM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 08:27 PM
Copyright ©1999-2017 diyAudio
