Pictures of your diy Pass amplifier - Page 198 - diyAudio
Old 15th June 2013, 02:04 PM   #1971
lanchile's Avatar
Originally Posted by carsten.witt View Post
Hello together,
Please, see next answer (last sentence).
I don't know how much it is, Alex said it to me but i don't remember.
So, i asked Alex via mail and wait for a respond. Some other pics from Alex.
Wow that is HUGE!!! too bad the blades of the heat sink are horizontally, I think it will dissipate heat faster and easier if the blades are vertically.
Make it simple...Make it better!
Old 15th June 2013, 02:10 PM   #1972
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by boywonder View Post
Hi Andrew: I'm not sure I'm following you here....what can I do differently at the RCA sockets?
its fine
Im more worried that the long brass connectors could touch each other if one accidentally loosens and turn
very nice clean amp
Old 15th June 2013, 02:16 PM   #1973
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by AndrewT View Post
Have a look at the aerial loop in the Signal wiring at the RCA sockets.
You must reduce that loop area considerably.
He is using shielded wire and it goes directly to the inputs of the amp PCB...
I'm not entirely sure how it could be made shorter... Am I missing something?
Old 15th June 2013, 02:17 PM   #1974
lanchile's Avatar
My F4.....it's been done awhile, just got around to snapping a few pics.
Very nice job! I think AndrewT is saying the RCA terminal are a little wider open than it should be. I do not think that is too much to worry about, as long as amp does not have any "back noise" all should be fine! I always use triple shielded microphone wire to connect the inputs and I have not encounter any problems with any back noise. so far..so good!
Old 15th June 2013, 04:41 PM   #1975
bcmbob is offline bcmbob  United States
Andrew, Is this what you are calling a loop? Through the negative/ground?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 15th June 2013, 05:26 PM   #1976
not that.
Look at the back of the RCA socket.
The shield is connected via a wire that is then soldered to the solder tag.
Look at the gap between the Signal wire and the grounding wire.
That gap is a loop. It picks up interference.
The loop can be made at least ten times smaller in area and with care maybe even reduced to 1% of the existing area.
Bare a tiny bit of signal and insert such that the screen nearly touches the free end of the RCA. Solder the signal to it's receptacle. Solder the screen to the end of the RCA using a tiny length of strand from a multi-strand core. If you are really careful you could try to solder 4 strands around the end of the RCA stub arranged at 90. These extra strands contact the screen around the periphery of the screen.
Until I read Ott, I had not realised how important the complete circumference of the screen is to making the screening effective.
Ott repeatedly tells us to NOT use a screen pigtail.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 15th June 2013, 06:31 PM   #1977
lanchile's Avatar
Hi AndrewT are you talking about this in the "coaxial cable"?Extron Electronics - Answer: Hum, Buzz, and Ground Loops
Old 15th June 2013, 07:59 PM   #1978
fig5 shows and notes the problem.
The area between the pigtail and the signal must be minimised.
regards Andrew T.
Old 16th June 2013, 06:17 AM   #1979
I should have added that the screen should extend all the way to the connector.
regards Andrew T.
Old 16th June 2013, 01:37 PM   #1980
boywonder's Avatar
Originally Posted by duder1982 View Post
Nice and clean boy, where did you get that chassis.
Duder: I built it using HeatsinkUSA 10.80" heat sinks, and aluminum angle and plate from a local metal supply house.
Hi Andrew: The screen/braid is tinned and soldered to the ground tab (no lead wire), but I suppose that I can make that entire joint a smaller "loop".
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright 1999-2017 diyAudio
